Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 67
Thread: chassis recipe, introduction.
    VANZEN
    twin-shock chassis recipe, discussion.
    This thread will not be to everyone's taste.
    It's contents will provide a comprehensive strategy to improve the handling characteristics of a twin-shock air-head
    a not entirely my own and not-so-secret "BMW Road Kill Cafe Recipe".
    A plethora of information, mis-informatiom, and idle after-market advertising hype exists regarding this topic,
    and together, maybe we can sort it all out.
    All discussion is welcome, but please note:
    My recipe, after all, is not intended to be THE definitive menu but rather just an example of one rather tasty "dish" ...
    an inexpensive dish that would suit my taste, may suit yours, but will still prove too spicy for many.
    So, if "spicy" ain't your style ... perhaps best to pass this one up ...
    for the rest, let's get on with it then ...
    The twin-shock air-head chassis was designed by the factory with then available technology
    to be flexible in order to cope with a variety of road surfaces and conditions,
    to be fairly competent in all possible riding situations, albeit extremely proficient in none.
    As good and well received as this marketing strategy was,
    it remains a compromise intended to appeal to the largest number of potential customers / riders most of the time.
    The truth of this statement will be witnessed by the extensive chassis modifications that altered the Butler-Smith / Udo Gietl 1976 R90S
    in order for it to be a successful competitor and Superbike championship winner.
    The first point to note, then, will be that
    modifications here are intended to improve chassis behavior when ridden fast on paved roads,
    and that performance on dirt roads and marginal surfaces will likely suffer.
    The resulting chassis will be more focused and less versatile.
    Next, THE FIRST & ONLY PLACE TO START WITH CHASSIS IMPROVEMENT
    WILL BE A STOCK CHASSIS THAT IS OPERATING AT 100% EFFECTIVENESS.
    If your riding skill and style does not approach or surpass the limits of stock chassis design capability,
    any improvements to the system will prove moot.
    And finally, improvements will be relegated to stock components as if we were considering building a bike
    to (loosely) satisfy AHRMA Vintage 750 Sportsman Class rules relative to chassis modification
    i.e. no late model forks system transplants, custom frames, or mono-shock conversions.
    Why do I emphasize "twin-shock chassis" ?
    Because the factory effectively dealt with many, but not all, of the issues we will address here
    with the introduction of the mono-shock platform and improvements continued
    throughout the rest of the air-head model run.
    Intro:
    The motorcycle chassis and chassis dynamics must be considered as an INTEGRATED SYSTEM.
    Having said that, I will attempt to order this recipe in hierarchical terms of (my perceived) importance.
    I will deal with these three sub-systems individually
    Part 1, forks system and front suspension,
    Part 2, main frame, and
    Part 3, sub-frame and rear suspension.
    stay tuned ... Part 1 to follow ...
    VANZEN
    featherbed knock-off
    Quote Originally Posted by PT9766 View Post
    It is my understanding that the twin shock "airhead" frame is basically a copy of the Norton "Featherbed" frame, according to Hans-Gunther von der Marwitz - as quoted in "Bahnstormer" (p.141) by L.J.K Setright.
    PT9766
    Norton Feathebed:
    The design is quite similar,
    including the rather odd method of routing the main-frame's "spine" to the bottom of the neck-stem tube –
    a concession to CoG in order to keep the weight of the gas tank and it's fuel lower in the frame,
    and this to the detriment of neck-stem area rigidity.
    Norton compensated for this flaw, however,
    and this will be an important and major distinction between the two frames.
    The Norton featherbed frame has an integral design feature,
    what is referred to as a "head-steady" –
    A rather stout bracket that connects the frame just below the neck stem
    to the head casting of the engine.
    This attachment, and the engine mountings on the bottom frame rails
    allow the engine case to function as a structural frame element / reinforcement,
    dividing the rather rectangular profile of the frame in half on a diagonal
    from the neck stem to the swing-arm pivots.
    This use of "triangulation" greatly increases the Norton frame's ability to resist distortion,
    and is an important element in the success of the featherbed design.
    BMW engineers were apparently absent that day ...
    as no such attempt to triangulate the Type-247 frame was incorporated.
    This will be the reason why the BMW frame flexes significantly at the neck-stem requiring reinforcement of this area.
    And also why "frame-braces" have become so popular.
    A relevant quote concerning the handling qualities of the Norton featherbed, considered excellent in it's day:
    "What does allow the handling stability of most British bikes is the
    normally minimal amount of power, relative evenness of its delivery and the
    fact that the state of technology in the rest of the world during the
    British heyday was worse."
    shire2000
    This should proove to be very interesting. I am certain that we can all learn something from this thread. I look forward to reading your "Recipe". Do you plan on any simple drawings or references to such so that we can follow along? Some of us need pictures to stay focused.
    Yarddog
    Lookin' forward to what you're gonna share...so far, in my one month of BMW ownership, I haven't been overly impressed about the engineering of simply things on my R100/7...maybe this will help me be impressed a little more...
    RecycledRS
    Can't wait for more!
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    +1
    Pass the mustard and UP THE REVOLUTION!
    Living the Legend Bigrider's Avatar
    Sep 2004
    San Antonio, Tx
    Well!!! We are waiting!
    Albuquerque, NM
    Just think--after all this effort an Oilhead will still be better!
    Kent Christensen
    21482
    RecycledRS
    Nudge, nudge.
    VANZEN
    The terms are well defined
    A statement that I have myself made numerous times,
    but also one that will be irrelevant here, Ichris.
    The subject is clearly stated:
    "It's contents will provide a comprehensive strategy to improve the handling characteristics of a twin-shock air-head –"
    ... not intended to be a comparative analysis of disparate technologies,
    or a philosophical and economic justification of pursuing the goal.
    It is intended simply as a "HOW TO"
    and a discussion of the practical merits of those procedures
    Quite busy at present, re-roofing the shop ... then headed to Hunter.
    Will continue with this ASAP.
    In the meantime –
    put the popcorn down. Anyone is welcome to share their ideas ... regarding the topic –
    Aug 2004
    Fly Over Land
    This post made me chuckle.
    Anyone who is a member and participates online in this forum is engaged in a past time which the vast majority of the world considers irrational at best. Therefore; as a member the idea of the thread as you laid it out makes perfect sense to me.
    Your posts in the past have often included the why of doing some modification along with the how you did it. I dont plan on running out and starting a twin shock BMW project but find that information very valuable for approaching other projects real or imagined. I hope you will continue to focus on telling and discussing the whys of your strategy along with the hows.
    JAMESDUNN
    And so will a number of other modern motorcycles. I love my oilhead but enjoy my airhead for what it represents. I will check in now and again to see what transpires. Perhaps I will gain an idea or two.
    I haven't even read every word yet, and I've already learned a few things.
    This will be cool.
    BUBBAZANETTI
    Quote Originally Posted by vanzen View Post
    hope to meet you there, i'll be the young doofus making a weathered R80ST look like a circus bear bike.
    Albuquerque, NM
    The subject is clearly stated: ...
    And you think you can tightly control the subject and the responses?
    How about you start by listing your engineering background that qualifies you to do this ... you know, as part of the ego trip you're so kindly "volunteering" to afflict on the rest of us?
    Oh, and please spare us the "reality TV" junk, like working on your roof. We don't care.
    Kent Christensen
    21482
