Results 1 to 15 of 40
Thread: KGT Rear Drive Fluid Change Model Year 2009
Hybrid View
    Aug 2008
    Kingston, NH
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    Introduction
    This pictorial deals with the changing of the final drive fluid in the rear drive.
    The procedure is broken out into four stages:
    • The first stage is the preparatory work to get the bike to do a final drive fluid change.
    • The second stage is the rear drive fluid draining
    • The third stage is refilling
    • The fourth stage is the re-assembly
    Aug 2008
    Kingston, NH
    Tools
    Aside from standard mechanics tools you will need:
    - T25
    - T40
    - T45
    - T50
    - 6mm Hex
    - Assorted 1/4" and 3/8" drive extensions
    - Torque wrench
    Bike Information:
    2009 KGT 1300, ABS/ASC
    The 2009 model rear drive does not require it to be "dropped" to change the fluid as there is a drain plug installed.
    Also on the 2009 Model the fluid is replaced thru the fill hole instead of the Speed Sensor
    oooo
    Aug 2008
    Kingston, NH
    Stage One - Preparatory Stage
    The preparatory stage consists of:
    • Putting the bike on the centerstand on a flat stable surface. - not shown
    • Remove both saddlebags - not shown
    • Taking the muffler off
    • Taking the rear wheel off
    Once the rear wheel is off the decision path for either the fluid drain or the spline lube can be determined.
    Aug 2008
    Kingston, NH
    Muffler Removal
    Using a T-25 Torx remove the shield covering the exhaust by the throttle-side foot peg.
    Aug 2008
    Kingston, NH
    Note tongue and groove secondary capture design
