Results 1 to 7 of 7
Thread: Conspecuity Lights (Lite Buddies & Stop Alert)
    GREGFUESS
    Is anyone concerned about conspecuity lights on the rear of their K12? What are you doing to increase visibility?
    There is an LED turn/running/brake light package called LIte Buddies, has anyone used them on a CANBus system?
    I have tried to install them on my 2008 K1200S and the wires are a very tight fit in the turn indicator housing, and the running lights have not worked, but the red brake light burns continuously. The LEDs brightness is satisfying, but I cannot use them if the red lights are burning all the time.
    Appreciate any and all thoughts and ideas
    Greg
    Sep 2006
    You may have to call the manufacturer to figure out color code if the instructions are generic. You may need to swap the leads,sounds like you may have the brakelight lead on the taillight circuit...happens!
    I use HyperLites and put them on the angled license plate assy. I had these on an RT, swapped them over to the S. All the wiring can be neatly routed so it does not show.
    Steve Henson
    Aug 2008
    Kingston, NH
    Another option to you is the supplimental brake light made by BMW
    http://www.maxbmwmotorcycles.com/fic...t&model=K1200S
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Brake Lights
    These work nice,
    http://www.p3lights.com/
    I have them on a 05 LT
    Registered User rmarkr's Avatar
    Mar 2007
    Lowcountry
    Shameless Hijack
    My riding mates tell me my bike is not visible enough from the front so I am adding two driving lights.
    How should they be controlled? Always on, each/both switchable? Any ideas?
    They are small 55w lamps, with a flat fan spread.
    Mark
    "Of all the things I've lost, I miss my mind the most" Mark Twain
    Aug 2008
    Kingston, NH
    Shameless Hijack answer
    I would say switched - that way you have an option to turn them off.
    Run the lights thru a relay to take the main load and use the light switch to activate the relay.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    GREGFUESS
    Visibility
    Yea, that's why I am asking, too. My GF rides an R12R and says the headlight is invisible during the day, even after having the shop adjust them. They are definitely on, just burn at about 1 candle power. I am exploring the EFX Slim Motorcycle Conversion Kit. Does anyone have any experience with those?
    The Lite Buddies and Stop Alert are a bit of a disappointment. The "running lights" are not very bright, not as bright as the pictures of the lights pictured above and the stop alert only flashes the running lights, not the brake light. C'est la vie, live and learn. The LED turn indicators, though, are much brighter, and that is a plus, though an expensive one. These were purchased from Pirates Lair.
    Greg
    08 K12S
