Results 1 to 5 of 5
Thread: Remove/clean fuel pump sock (late model K)
    BMW uber alles! Zagando's Avatar
    Apr 2007
    Rockport, TX
    Took the fuel pump out to inspect it well.
    The sock/screen on the bottom seems to have rocks inside it---perhap some kind of media to keep it from collapsing?
    Anyway, it could use a cleaning.
    Can I pry it off and soak it in acetone or Simple Green/rinse/dry or should I attempt to brush it or soak it while still attached the the pump?
    ---Jeff
    ex: K75S Berlina R100GS/PD , K100RS , R75/5 , R60/2
    Rally Rat Roc-Roc's Avatar
    Jun 2004
    Indiana
    You can order another one to replace that one. Its snaps on.
    Roc
    Apr 2007
    Rockport, TX
    Thanks, but I simply want to clean this one and reuse it for now if possible.
    ---Jeff
    Apr 2007
    Rockport, TX
    Smile Sock update
    I got it pried off and while the metal ring that snaps onto the pump inlet was rusty all is well otherwise.
    It is now soaking in Simple Green and will be put back in service after rinsing and drying.
    ---Jeff
    Apr 2007
    Rockport, TX
    Oops!
    After drying I reinspected the sock---has a tiny hole in it so will order a new one pronto. Glad I took another look with my microscope (sometimes I think it's worth it's weight in gold!).
    ---Jeff
