Results 1 to 15 of 252
Thread: K75S DIY painting (& polished tank) thread
Hybrid View
    Apr 2007
    Rockport, TX
    Recently started work on my big summer project---painting my Dakar Yellow K75S a different color and polishing out my aluminum tank.
    Thought I'd start a potentially long-running thread here to show the whole process for anyone interested and to solicit comments, questions and advice.
    I'll begin by posting some photos of my bike as it was, how it is now and some of the steps of the painting, polishing and preparation process now in progress.
    BEFORE:
    NOW
    (June 28th):
    After reading many different posts on this and other Forums (ADVRider in particular has lots of painting/bodywork experts) I decided to DIY the whole job instead of farming out the work to a paint shop.
    I decided to use a Fuji Mini Mite* 4-stage HVLP turbine paint sprayer with a Fuji gravity fed (and pressurized) gun---instead of going with a more conventional big air compressor/conversion gun setup---for a number of reasons:
    The powerful turbine's compact size, warm & dry air that won't require moisture filtering, ability to work in tight spaces, very fine paint atomization and far less overspray. The Fuji also has rec'd. excellent reviews and features the same 4-stage Ametek-Lamb turbine found in all of the top tier HVLP turbine systems. Overall cost was about the same or actually less than the good quality big compressors.
    I will use 1.0mm and 1.4mm aircaps for paint and primer.
    (*I bought mine from a Wisconsin Fuji distributor who had many informative video clips on his website that helped clinch my decision---Google Roger Phelps or Phelps Refinishing for his url---I certainly will recommend him to anyone considering such a system)
    I also purchased a Breath Cool II fresh-air respirator system (available on ebay) to protect my health during spraying. The PPG polyurethane paint I will be spraying has extremely hazardous isocyantes in it (they can glaze over your lungs and dramatically shorten your lifespan in no time!) so I decided not to take any chances (facemask respirators with paint cartridges don't cut it with this type of paint).
    For the polishing of the tank I bought a Makita 7" professional-grade buffer/polisher and got some extra foam pads and polishing compounds. I am still loooking into clearcoating the aluminum once it's polished but I am hearing different things about that subject. I may first try waxing the aluminum to protect it against our highly corrosive atmosphere here in Volcano, Hawaii.
    Besides the salty and humid air of the lowlands we have year-round volcanic acid rain here in the highlands. Kilauea's summit is only 4 miles from where we live.
    This will be an interesting "polished aluminum experiment." I will probably be asking for further advice on this subject as I go along. I also plan to cover the low Sargeant seat with a black sheepskin or leather look-alike and remove the rubber tank surround completely. I'll build up the saddle to fill in the gap between the tank and seat and also make it a bit higher for the benefit of my long legs (and aging knees) If my results with the tank are worthwhile I'll want to show more of it off, too
    I will be doing most of the spraying and polishing either outdoors on a (rare) dry and sunny day or in my small bike shed (not pictured) that I will convert to a makeshift spray booth i(f I get too many bugs in the wet paint).
    That's most of the info for now. I'm going to start soaking all the tupperware from the bike in Simple Green for a thorough cleaning before I begin the sanding...
    Stay tuned if interested---I will post pictures, questions and comments from time to time and I welcome all of you reading this to feel free to respond as you wish anytime
    ---Jeff
    Count me among the interested.
    looking for a coal mine knary's Avatar
    pdx
    Apr 2007
    Rockport, TX
    Smile Hope you guys don't run out of popcorn...
    Been busy with other stuff and haven't had much time to continue work this week.
    I did remove the fuel pump and filter for the first time and posted my findings elsewhere in this forum. Had some varnish crystals in the tank and the fuel filter needed replacing. Inside is all clean now.
    Tomorrow I hope to put everything back inside the tank and seal it up before starting to sand off the paint.
    Progress here may be slow but that's because I'm getting older and don't seem to get as much done in one fwell swoop like I used to.
    But once I progress to the next significant stage I'll take and post some pictures to keep everyone interested and informed.
    Cheers, Jeff
    ---Jeff
    Diamondhead, MS
    I'm looking forward to following this. My K75 tank has some scratches and I'm trying to decide how to proceed.
    Apr 2007
    Rockport, TX
    Smile Getting started on the tank at last
    Good timing on your post, Acejones.
    This is how I spent part of my Fourth of July (about two hours of hard work even with the help of my electric detail sander used at the start, with 60, 100 & 150-grit sanding discs).
    Here's the back of my tank after reaching the 220-grit stage wet-sanding by hand:
    (I decided to do the back first in case this all goes horribly wrong and I decide to paint it instead)
    Still has a couple areas of imperfections that I need to attend to:
    ...but overall I'm getting excited with my results and looking forward to proceeding further (320, 400, 600, 800, 1000, 2000 and then rubbing & polishing compounds with the Makita 7" buffer).
    I'm pretty tired today after all the work I did yesterday (also had to fill in for my wife at her housekeeping job while she's out of the country for two weeks) otherwise I'd be back out there again today working on the tank more. I also have my regular bartending job tonight and tomorrow night so I'll probably continue with this fun project on Tuesday or Wednesday when I have some free time. (stay tuned; I'll post more photos soon after completing the next stages)
    I plan to go through all the grits on just this small section and polish it to see how it turns out before doing the rest of the tank.
    Meanwhile I put a post over on the ADVRider Garage Forum wondering about protective coatings for bare aluminum.
    Any ideas here on wax or Eastwood's Diamondclear? I've heard clearcoat doesn't usually stick to bare aluminum well.
    A couple of ADVers suggested anodizing (clear anodizing will dull the color a bit, I think) or clear powdercoating. Hmm, am giving these a thought but am hoping to hear other ideas, too. What about a good paste wax?
    I might still end up just leaving it bare except for weekly polishings with Mother's Mag Polish---that stuff is great!
    ---Jeff
