Results 1 to 4 of 4
Thread: Run power for iPhone
    Apr 2009
    Washington, D.C.
    I have a RAM mount for my iPhone and it works well... however the biggest limitation is power... when using it for bluetoothed calls,or now with the new version as a turn by turn GPS, it can drain the battery pretty fast.
    I would like to figure out a way to build a power harness so I can charge it through the power port on my RT...
    I would need a simple USB charger... which would be awesome in mulitple ways or a simple BMW version of an inverter that plugs into the bike and has a standard power port on the other side. Does anyone know of anything like this that exists?
    Otherwise, I am going to have to break out the soldering gun and build my own wire, which I dont totally want to do.
    Thanks in advance...
    B-1 Pilot
    Urbana, IL
    You could use the i pod car charger plugged into a car socket with a BMW plug on the other end? Lots of conversion wire assembly things like that on the market incl one by BMW.
    http://store.apple.com/us/browse/hom...oneAccessories
    My other bike is a BMW.
    Apr 2009
    Washington, D.C.
    I thought about that, but wanted something a bit cleaner and at least water resistant...
    found someone reference this product over on ADVRider..
    should have searched a bit more
    http://www.powerletproducts.com/prod...ging-cable/420
    B-1
    Registered User DPeakMD's Avatar
    Sep 2007
    Franklin, IN
    I'm currently using an iPhone on a RAM mount which is attached to the Migsel mounted on the fairing of my 1150RT.
    I like the Griffin line of accessories for keeping the iPhone charged. They are fairly compact and adaptable. I can charge from USB plug on computer, 12V auto port, and 120V outlet with the same cable (or use the one that came with your iPhone instead). The Griffin 12V charger also has built-in surge protection and an LED that lets you know it's hooked up and when it's charging. They are coming out with a new system that uses a small rechargeable battery that plugs into the bottom of the phone to re-charge it. I'm probably going to get one when they're available and try it out. Then I could charge the external battery in the tank bag and plug it in when needed.
    I don't have a good solution for recharging other than running a charger cable which uses a BMW to cigarette lighter converter and then the 12V Griffin adapter. The Powerlet cable looks very nice, but it's a "Unitasker" and I'm opposed to that notion since space is at a premium on a bike. I prefer a system with more flexibility.
    Nothing about the iPhone is even remotely water resistant, so that's not high on my list, either. I've looked at using the RAM Aqua Box for the iPhone. The plastic membrane does not seem to work with the iPhone's touch sensitive screen. At least for me it doesn't.
    I find that the display is a large consumer of juice from the iPhone. So I use it just for iPod and phone and use a Garmin for guidance.
    Dallas
    2011 R1200GS Adventure
    Smoke Grey Metallic Matt
