Results 1 to 13 of 13
Thread: 220,000 mile K12 LT (99)
    Dec 2008
    Modesto, CA
    Good morning. My 99 K12 has just over 220,000 miles and I've not had to touch the engine. A clutch, exhaust system and a rear bearing, but nothing on the engine. I recently noticed that when I start it in the a.m. it blows a puff of blue smoke, then it clears up and runs great. Is there anyone else out there with this many miles that has the same problem? Thanks in advance.
    Modesto Mike
    Feb 2006
    Long gone
    Mike,
    I moved your post to the K bike section so you could get more exposure from folks likely to have an answer to your question.
    Bud
    Ride Well
    Dec 2008
    Modesto, CA
    Thanks Bud.
    Mike
    Oct 2008
    Laurel, MD
    Well Blue smoke = oil. Do you keep it on the side stand or center stand?
    Dec 2008
    Modesto, CA
    I put it on the center stand at work..but the side stand at home. I have noticed that that makes a big difference in the "puff" of smoke in the a.m. I'm thinking it might be the valve stem seals??
    Jun 2007
    I think it is a K with 220K on it. See the 'sticky' on smoking K's above......
    Jim Douglas '00 K1200RS >136,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Quote Originally Posted by MSHELTON146301 View Post
    Modesto Mike
    WOW 220K!! You get a lot of miles in. NICE.
    I only have about 45,000 on my '93 brick and it does the same thing. I go through about a quart of oil in 1000-1200 miles and nothing is leaking. 99% of the time it is on the centerstand.
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    '12 Suzuki DRZ400
    ("kid's" bikes) '02 Kaw ZX6R- Jen's '07 Duc 800ss- Johnnie's
    Dum vivimus vivamus ted's Avatar
    That would be my guess.
    Ted
    "A good stick is a good reason"
    1994 K75RT
    Moto Pages
    Dec 2004
    Winnebago, Il
    Modesto Mike
    Does use any oil in significant amounts? I.e. quart every 1,000 miles
    I think this used to be check for bad valve stem seals on V-8's.
    Procedure was to run them at higher RPM's for ways while driving down the road. Totally let off of the gas and decel for aways and then reapply throttle. If they smoked it was drawing oil in around the valve stem seals. Not sure if this would work on a horizontal engine or not.
    No I don't have that many miles on my two K-bikes combined
    Roy
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    Registered User thompsonr's Avatar
    Nov 2007
    Topeka Kansas
    At 220,000 miles I would not worry about a puff of smoke on start up I have a friend with 2000 Lt that smokes on start up with less than 40K on it.
    Id kiss the old girl on the windshield for starting and ride off into the sunset with a big smile....
    R and R
    Dec 2008
    Modesto, CA
    Thanks for the replies...
    Thanks for all of the suggestions. It really doesn't use hardly any oil at all. Actually, it's running as good or better than it did when it was new. If I had to guess, it's probably using a quart every 3-4000 miles. I use Mobile 1 fully synthetic 5-30. I think I'll stop worrying about it and just enjoy the ride. What a great machine!!! I commute from Modesto, CA to Oakland everyday. About 75 miles each way, so the miles add up quickly. Thanks again everyone.
    Boise, ID
    5-30 is a bit light for the factory recommendations which is 15-50. Try the correct oil viscosity and see if that makes for an improvement.
    Greg Feeler
    BMW MOA Director & Ambassador
    Jun 2007
    15-50 especially from Modesto to Oakland in the summer, that is a warm ride for 30 wt. When I commuted from Fiddletown to Sac, I would sometimes go to a 5-40 or so in the winter when temps were at or below freezing, but always a 50 for summer temps. But, heck, if you have 220K, why change?
