Results 1 to 15 of 15
Thread: Tire changer
    On the Road
    Tire changer
    I'm looking for a tire changer for motorcycles. Do you have any sugestions?
    Blocking the slow lane
    Elburn, IL
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Focused kbasa's Avatar
    Marin By God County, California
    Originally posted by jdiaz
    Coats 220.
    Look here: http://www.klsupply.com/wheel/coats220/
    Looks nice.
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    On the Road
    Tire changer
    How much does the coates model 220 cost?
    Elburn, IL
    I think they are under $1000.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    What's that noise...? basketcase's Avatar
    Alabama
    I have heard good things about this one from Harbor Freight. Reading the verbiage, I think it may require the basic tire changer as a base.
    Eventually, I'll figure out how to do "clean" hyperlinks.
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    Registered User drtbyk's Avatar
    North Central Washington State
    IMHO the only tire changer worth having is a Coats 220 (unless of course you can afford one of the Coats big-rigs). I've had mine for over 18 years now and when I need replacement parts, no problem.
    You should be able to find a new one for ~$700. Try scoping out your local larger bike shops. They often sell off older ones if they are moving up to more automated changers.
    Cheers,
    Dan Townsley
    All Things GPS
    Love that floor - Is that standard tile?
    Dave Swider
    Marin County, CA
    It's your regular 12x12 white and black tile.
    Cheers,
    Dan Townsley
    All Things GPS
    I assume it's in the garage. Have you had any trouble with the tile lifting under warm tires?
    I need to do something for my flooring and have considered tile.
    Man. I starting to think we need a "Show your Garage" thread.....
    Dave Swider
    Marin County, CA
    Actually that's my workshop. The garage is still unfinished. My usual practice is to use gray epoxy in the garage.
    Cheers,
    Dan Townsley
    All Things GPS
    That's what I used in Boston, the Ben Moore Silicone based epoxy concrete stain.
    Everything would just bead on it.
    Dave Swider
    Marin County, CA
    On the Road
    Coates model 220
    Can you tell me Coates web site address. I tried to locate and I'm not having any luck.
    Coats Manufacturing does not sell direct. You might try just searching on COATS 220 and you should come up with a couple of distributors/sellers.
    Here is one I came across:
    wikco.com
    and the price seems about right since it looks like they include shipping. Good luck.
    Cheers,
    Dan Townsley
    All Things GPS
    Ancaster ON. Fort Piere FL
    Chris
    MOA#56216
    IBA#11157, 48States Plus
    2001 R1150RT-84Kkm
    2000 K1200LT 48Kkm
    Deep in my heart Eagle's fly...
