Results 1 to 15 of 17
Thread: Wrist pain
    Nov 2005
    Lancaster County, PA
    Wrist pain
    OK, so this isn't really related to Wedge bikes, but wasn't sure where to post, so here it goes. I ride a K1200S with a K1200R top triple clamp installed. This weekend was my first experiance with longer distances on this bike and I found that after 4-5 hours, my wrists were quite sore, mostly the throttle hand. I have a Throttlemeister cruise control installed, and used it when safe. I try to change positions on the bike fairly often, but nothing seemed to help. By the 11th hour I was thinking of selling the bike..............not really. Any suggestions? How can you tell what the problem is? There are a couple riser types, but how do I figure out what the issue really is?
    Any ideas are appreciated.
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Have you tried one of these?
    Seriously. I have a Throttlemeister too, but being able to just rest my mostly open hand on the "gas" (I find) takes a lot of the strain off my wrist. Cheap too.
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    SS1000, BBG
    Nov 2005
    Thanks John, no, I've never tried one, maybe that should be the first step.
    May 2007
    Raleigh, NC
    Here's my take on wrist pain:
    A) Both wrists: You are either grabbing too hard or locking out/arm pumping. If you ride a lot of other bikes and don't have the pain, then you probably aren't grabbing too hard. You'd feel that pain on any machine if that were the case.
    Locking out your arms and putting pressure on your wrists/forearms to hold you up, especially when braking, is the next likely cause. This could be you as a KS is very sporty and will put your weight forward. You need to use your legs, gripping the tank, and your core to hold you up. You should always, even when dragging a knee around a corner, be able to wiggle your arms, indicating there is not too much weight on them. In a tight corner, your throttle arm should be more in a screwdriver type alignment with the throttle. Try making sure at various times that there is not a lot of weight being absorbed by your arms. Finally, be sure to ride a bike like that with the balls of your feet on the pegs, not the pegs 'wedged' into your heels. This is poor posture that does not allow your legs to do their share of the weight bearing. Failure to teach this proper foot positioning is one thing that the MSF class could really improve on.
    I just did a full track day at VIR and today my quads are sore as hell, but my arms are fine!
    B) Pain in just the right hand: This is due to the work the hand must do to operate the throttle. You might be grabbing the throttle too hard, but really, when I ride my CBR600RR for more than 2 hours, it gets to my hand as well. Holding a throttle open for hours is tiring, and the throttle devices like the one shown should help a lot.
    Robo
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Apr 2007
    Penn Hills, PA
    Quote Originally Posted by SugarHillCTD View Post
    Tried one for the first and last time on a ride from Cape Cod to Pittsburgh last year. After a long wet slog, pulled into a crowded service plaza and as I was negotiating a tight right turn around some autos.. and with the bar set as it is on the K12s, the throttlemeister was depressed against tank. Can you guess the rest? There are two sizes, and I suppose the shorter of the two might have allowed me to escape the calamity, however I am not going to experiment.
    Back to the service plaza, what I remember was the power as the rear of the bike went 270 degrees before I got the clutch and brake squeezed. Tired and damp I didn't think to flip the device out of the way. I'm glad nobody could see how ghost white my face turned through the visor. The kids in the minivan were impressed though.
    BeemerBoy terham's Avatar
    Feb 2005
    Exit 31, PA TPK
    Quote Originally Posted by john1691 View Post
    I'd have to borrow your bike for 4-5 hours to really tell. Would Saturday work?
    I use a cramp buster on longer trips, and find they work quite well, but they are a pain around town. Position changes on the bike, relaxed arms and frequent stops works for me. I also find riding after longer layoffs can make for sore wrists. I think you need to ride more.
    Terence
    R75/5 R100RS K100RS R1150RT
    My Smugmug
    Tiverton, RI
    I've been using the wrist rest for at least 10 years now. I run both left and right side wrist rest. Sence using them I hardly ever use my throddle lock. I believe I purchased them from Bob's BMW, though its been awhile. Good luck in what ever way you go.
    www.OceanStateBMWriders.com
    2014 R1200GSW Rich's Avatar
    Sep 2003
    Killdeer, ND
    Quote Originally Posted by r11rs94 View Post
    Left side? How does using one of them on the left side help anything?
    I'm missing something here.
    Kimberton,Pa.
    If you have ever ridden horses..especially bare back..you ride with your thighs..in other words...keep your knees tight against the tank area and keep the weight off your wrists especially at low speeds. I have many a LD trip using this concept and have kept the wrist pain as you mentioned down to a bare minimum...
    Hope this helps...
    Clay
    Kimberton,Pa.
    RK Ryder
    London, Ontario
    My wrist pain from a couple of summers ago was eliminated last year after installing bar backs.
    Paul
    Knights of the Roundel #333
    Nov 2005
    Quote Originally Posted by terham View Post
    Terham, Saturday is calling for rain, but I'll be in Galveston, TX, starting Monday, doing some Hurricane "Ike" repairs for a church down there, so the bike will be here, alone in the garage, so feel free to borrow it, just make sure the tank is full and a nice bottle of Bourbon in the tank bag when you return it.........................
    Nov 2005
    Thanks, everyone for the input. Sounds like I need to work at keeping the weight on my back, with the help of my legs, and will probably purchase a "Wrist Rest" as well. I was supposed to help lead a 12 hour group ride to WV and back next Saturday, but a last minute trip to TX will cause me to miss out on that ride and allow the wrist to heal longer before my next long day of riding.
    Thanks again,
    Braintree, MA
    If you've got big hands (think 2XL gloves), a wrist rest is trouble waiting to happen.
    -Tom (KA1TOX)
    Feb 2005
    Exit 31, PA TPK
    ...and a nice bottle of Bourbon in the tank bag when you return it.........................
    Well, I guess that's another way to deal with the wrist pain.
    Terence
    My Smugmug
    Oct 2007
    Quote Originally Posted by tommcgee View Post
    Why so? I have very large hands and have always used a wrist rest- never a problem.
    John & Cathy
    SS1000, BBG
