Results 16 to 19 of 19
Thread: Photoshop
    advrider.com
    Oct 2005
    I'm Old Skool. MS Paint.
    This summer, I'll give Photoshop a try. So, is CS4 the current standard?
    univers zero tessler's Avatar
    Aug 2005
    New York City
    Quote Originally Posted by crazydrummerdude View Post
    CS4 is the current release, but CS3 is in wider use and has all of the bells and whistles required (and then some) to really learn the program.
    Rally Rat grafikfeat's Avatar
    Lamble is gone (no comments) so this is for anyone wanting to pick up some info...
    If you have access to iTunes/podcasts there are many free podcasts on tips and tricks.
    For that matter YouTube as well.
    There is also Lynda.com for those really wanting to 'learn'.
    I too have been in Photoshop since 2.5.1 and the single most important tool IMO is quick masking.
    That is, the ability to isolate areas to work cleanly.
    The best upgrade Adobe did for PS was incorporating layers from 2.5.1 to 3. (not cs3)
    If you are new to PS there is no need for CS4.
    CS, CS2 are more than enough to learn while 3 and 4 all have minor tweaks in areas you won't be involved in for awhile.
    Then again, if you shoot "raw" you will want at least CS3.
    SW Ohio
    I still use PS-7 at home. If your cpu is older or memory disadvantaged, the older version usually run faster.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
