Results 1 to 2 of 2
Thread: i ABS Help!!
    i ABS Help!!
    2002 R1150r
    Last night while riding my ABS/Gen lights started to flash, alternating flash. Upon inspection I found one of the rear brake calaper bolts broke (rear bolt) I limped home after tightening the other. I have removed and replaced the broken bolt, checked the levels in the brake resevours, charged the battery...still flashing lights. The ABS apears to be working correctly.
    I have tried this, hold down both brake levers and then turn on switch...then the lights flash even faster?
    Any ideas???
    Wally 1150RT WREALINI's Avatar
    Dec 2007
    Irvine, CA
    Not an ABS expet but...
    Try disconnedting the battery for a few minutes.
    I was informed by a local tire shop that they wouldn't work on BMW's because they had an ABS that needed to be reset by the dealer after they had it apart for tires. I just assumed they didn't drive the bike to stop the light from flashing.
    '04 R1150RT
