Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 55 of 55
Thread: Who makes a good rain suit out there and what works?
  1. #46
    bob204bc
    I like the TourMaster 2 piece suit. Frog Toggs are built like crap.
    I have seen an H-D branded rain suit that has full length side zippers in the pant legs for easy entry and exit. Otherwise the suit looks similar in construction to a lined TourMaster Rain suit.
  2. 05-02-2009, 12:56 PM
  3. #47
    Registered User careycsg's Avatar
    Sep 2007
    Mt. Prospect, IL
    Quote Originally Posted by NavyDad View Post
    Tourmaster Sentinel two piece
    You got that right. Excellent suit at a fair price and available with lots of higher visibility yellow on the jacket portion.
  4. #48
    Canada and the Alps
    Quote Originally Posted by GlobalRider View Post
    My 2-piece Teknik rainsuit...
    Having just pulled it out of storage, I did find one annoying aspect on it and any suit like it that uses the same mesh lining.
    The "hook' material that runs the full length of the jacket's opening sticks like crazy to the mesh liner and is a pain to pull apart when you're in a rush to put it on.
    If it ever falls apart, I'll be looking at getting a suit with a smooth polyester lining.
  5. #49
    Jun 2008
    Atlanta, GA
    1995 K75 A/3 - Will the lifetime memberships ever come back? If so, I want one!
    Peace....Theo
  6. #50
    Uncle Bucks
    Sep 2009
    Brentwood, TN
    How do you size a rain suit?
    I would like to order a rain suit but not sure what size would work. Currently wear a XXL tall (6'4" and 230 lbs). Should I order the same size or maybe 1 or 2 larger? Thanks
  7. #51
    Sheboygan, WI
    Smile
    Quote Originally Posted by WDPittman View Post
    You're going to want to go bigger with the raingear.
    Reason why: Just because it's raining, doesn't mean the temps suddenly shot up. Often, you will want to leave all your warm (and protective) gear on, so the raingear should be a bit over-sized, especially to be able to cinch the neck tight so that water doesn't run in.
    If you need to wear only raingear, the over-sizing won't be that big a deal.
    Good Luck!
  8. #52
    May 2008
    Evanston, IL
    I'm 6'2"/240 and the 3X Frogg Toggs fits great over my gear.
    Geoff
  9. #53
    Get a Darien jacket and pants from AEROstitch RIDER Wearhouse
    DarienLight Jacket #260
    DarienLight Pants
    Works perfect for all around Texas + more weather + 100% waterproof
  10. #54
    Apr 2005
    Michigan's Upper Peninsula
    Froggs toggs..........
    The also make a suit for just motorcycles. Check out their website. They work great.
  11. #55
    Apr 2008
    Riverview, FL
    BMW KlimaComfort has been great. I have ridden in some torrential rain and never a drop. Expensive, but worth it.....and it breaths very well.
  12. 02-08-2010, 10:04 PM
