Results 1 to 5 of 5
Thread: lighting
    On the Road wack's Avatar
    RI
    lighting
    I am interested in putting some PIAA lights on my '96 R1100RSL Does any one have suggestions for placement and mounting options?? Any help would be appreciated.
    List Mistress mrskbasa's Avatar
    Marin County, California
    Unfortunately, I don't have them myself, but I have seen them mounted in two spots.
    Drilled into the Roundels (yuck) and attached to the "fork legs" on the front axel somehow.
    Tina Swider
    Sled Dog Touring Team
    Any bike I want that is in the garage
    RI
    lighting
    Thanks for the reply. I have talked to Duncan at his shop and having seen both placements you mentioned, I probably will go with a mounting bracket. Not sure where yet?
    Calgary
    I didn't spring for the Piaa lights, just some cheap ones from the local parts store. I made a bracket that spans between the sides of the fairing under the oil cooler and mounted the lights at the oute edges.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Middletown Ct.
    Have you Seen Piaa's mounted on Martin Fabrication Brackets?
    Cyclegadgets.com has them for a R1100RS
    I'm running Martin brackets on a RT with the 1100's they fill in the weak spots of the low beam and I'm not get flashed by oncoming traffic.
