Results 1 to 9 of 9
Thread: Autocom and a Yaesu HT
    Dec 2008
    Belle Plaine, MN
    I'm looking into a setup that would allow the use of my Yaesu VX-170 while I'm on the bike (85 K100RT). I currently have an Autocom Easi-Plus (9V powered/7 pin DIN) that I use for two-up intercom and music. My first thought was to build a patch cord (including PTT button) to connect the HT to the Autocom unit. The second idea was to bypass the Autocom unit and connect the HT directly to the headset in the helmet (again with a PTT button). Granted that the latter would be for solo use only.
    In either case, the first step is to locate wiring diagrams, and identify the proper pin connections. I would be greatful for any information on the needed connections and/or suggestions that could simplify the process.
    Thanks,
    Monte
    jjambor
    Here's what I have:
    Please note that J1 is specific to Kennedy interface products.
    jjambor
    as far as that note about keying via a 2.2k resistor: if you have the headset mic connected to the mic-hi and mic-lo lines, all you need to do is have the ptt complete the circuit and it'll key.
    Dec 2008
    Belle Plaine, MN
    Jon,
    The link to the image seems to be broken.
    Thanks,
    Monte
    jjambor
    weird... it show up in the post.
    Dec 2008
    Belle Plaine, MN
    That is weird. The post shows a red X as an image placeholder for me. I used the 'view/source' menu and located the img link of http://cellset.com/85543R0assydwg.pdf and was able to get to it that way.
    Thanks.
    Anyone know the pin out for the 3.5 mm 4 conductor inputs on the Autocom box or the configuration for the 7pin DIN connector for the headset?
    Sep 2007
    Virginia
    Here's a sketch of the Yaesu pinout:
    and the Autocom pinout:
    I used a VX5 on my K1100RS and it worked well.
    __________________________________________________ ____
    Motorcycle Visibility Lighting systems: Can You See Me Now?
    Dec 2008
    Belle Plaine, MN
    Looks like I have my weekend project lined up now.
    Thanks to everyone.
    Registered User DPeakMD's Avatar
    Sep 2007
    Franklin, IN
    Thanks for the good info here! Appreciate the pin-outs.
    Dallas
    2011 R1200GS Adventure
    Smoke Grey Metallic Matt
