Results 1 to 15 of 17
Thread: Tire Pressure Gage
    Impulse FrankFlorio's Avatar
    Saratoga Springs, New York
    Tire Pressure Gage
    Does anyone know a reliable tire pressure gage? I bought an Accu Gage and when I had Dunlop do a tire check at a recent rally, they found out my accu gage was like 6 psi off. gee wizz.........who ever thought ya need to calibrate them BUT.
    Does anyone know how to callibrate them as well? Thanks in advance.........................Frank
    '14 K1600 GTLE
    '08 R1200RT
    '08 F800ST
    '05 R1200RT
    Registered User texanrt's Avatar
    Nov 2008
    Lafayette LA
    I have a older dial accu-gauge and it's still accurate when compared to the dealer and TPM. I recently ordered a cycle pump gauge with the inline valve for filling tires and had to return it because it was at least 5 PSI off when compared with the other gauges and TPM. It's quality was questionable as soon as I removed it from the package -- the needle wasn't even on 0 PSI to start. Don't know where it was manufactured, but I have a suspicion.
    Don't know about calibration. I was just going to order a new accu gauge when I read your post and am having second thoughts.
    John H | TexanRT | Lafayette | IBA
    BMW R1200RT '09 | Honda Goldwing '12
    Chairman of the hoard wmubrown's Avatar
    Nov 2004
    Kalamazoo, MI
    Most, if not all, of the accu gage's have a lifetime warranty, I'd send it back to them and see what they have to say... maybe there was a bad run or something? I have the model EZ02 and haven't had reason to suspect its off, but I'll compare it now with a couple digital gages I have and see how they measure up.
    http://www.ghmeiser.com/contact.htm
    John A. Brown - Kalamazoo MI
    '09 K1300S 'Zoot' (Wicked, bad, naughty, evil, Zoot!)
    '94 K1100LT 'Desert' (the horse with no name)
    Aug 2004
    SW Ohio
    I Like these digital gauges
    http://www.cyclegadgets.com/Products...Item=TIREGAUGE
    I found one on close out at a radio shack for $5 They seem to be durable and accurate.
    Jul 2008
    Itasca, IL
    Check out Roadgear. They have the Ultra Hi-Tech Digital Tire Guage ($70) and Hi-Tech Digital Tire Guage ($25). The Ultra is cool because once you've attached the chuck onto the valve stem it allows you to reduce pressure with the press of a button. You don't have to take the chuck off until you're done. Both guages were rated high by Cycle World.
    Roadgear web site: http://www.roadgear.com
    Good luck!
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Schedule indicates RoadGear will be at the International in Johnson City.
    +1 for their digital gauges.
    Registered User robertklee's Avatar
    Mar 2006
    Tennessee
    Got several cheap ones. You know-apply it to valve stem and gauge pops out... They seem to work fine.
    RKL
    "Leave the gun. Take the cannoli."
    Registered User stkmkt1's Avatar
    Sep 2008
    Tremont, IL
    Yea. Take your thumb and push on the tire anywhere along the treaded area. If you are able to push in the tire, add some air. If it does not give, your good to go. Why bring a gauge into the mix and complicate things. Worked for years on bicycles anyway!
    Seriously, I was once told that the most reliable tire pressure gage is the old-fashion pencil style gages. They are also among the least expensive. I won't say this is the reason for my not buying a "modern" style gage such as digital, or whatever. But I can say that my pencil gages have yet to let me down. And one of them I'm sure I've had and used for 40 years.
    '09 BMW 1200 GSA, 2013 BMW 700GS, 2000 Goldwing SE, '09' V Star 950, '09 Honda Rebel,
    '77 Honda 750A. Holding at six til I get new garage built - need more room for more bikes!
    TGHSMITH
    best bet, the old style pencil type, look for one with a heavy head (chrome plated brass) with two grooves in it, hopefully its a shafer and not a cheap knock-off, for best readings get the 0-50psi, if you find the good ones by 2 or 3 that way you always have one...
    Registered User amiles's Avatar
    Jul 2003
    Murrells Inlet, S. C.
    There seems to be a recent idea that if a measuring device is digital then it is accurate and beyond question. I for one don't go along with this. I have no data to support this OPINION, but, I have found that in some cases the more complex that a device is, when used in a rough and tumble environment, lower reliability is often the result. I like my old $1.00 pencil gauge. I like the "Milton" brand. My old VDO dial gauge had the rubber gasket for the valve stem dry out & need replacement.
    At last year's rally there was a tire pressure chairman. Apparently (I think) they set up and would check your tire pressure for you. Someone will surely correct me on this if I am mistaken.
    If somesuch is planned for this year's rally I would feel it a much greater service if a calibration check on everyone's tire gauges could be offered. I don't imagine that many, if any rider's tire gauges are able to be calibrated, but if a rider finds his gauge is no good or learns a correction factor, something along the lines of the old saw of "giving a man a fish vs teaching him how to fish" will take place.
    It would be nice to check that new just bought gauge for accuracy.
    Calgary
    Quote Originally Posted by amiles View Post
    I have five different digital guages (one in each vehicle and one for the shop), no two the same brand or model. I have checked them all and each one is within 1.5 psi of the same reading. I checked them all on my truck's tires so that the testing would not be as affected by the loss of air on each test since the tires hold a larger volume than any other I have available. The pressure is comparable to the range I run in my motorcycle tires. So, either they are all out by the same amount or they are all pretty accurate.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Feb 2005
    N. Dallas 'burb
    An Accu gauge dial with around a foot long hose in the garage. Its got a pressure reliease valve and a) a pressure release valve and a dual foot chuck.
    And old fashioned pencil gauge for the tankbag. Several, actually, as they're cheap enough to own quite a few.
    I also have a fancy schmancy digital gauge. Its so pretty! And it has "BMW" emblazoned on the side. Truly a marvel to behold, and at $25 it ought to be. But one time on the road the darn battery went dead and it wasn't worth a thing. That's when I went back to pencil gauges for the tankbag. The fancy digital gauge sits unused in my toolbox as a monument to wasting money.
    Grant
    '05 R1200GS
    Former owner of an '03 R1150R
    BMWMOA #113847
    Registered User gimmeshelter's Avatar
    Nov 2008
    Detroit
    Don't know how accurate it is but I stopped at a Snap-On truck and bought a nice dial type which was around $20 and appeared to be good quality.
    Sep 2007
    So. Calif.
    Amazon.com has a number of good looking gauges. I bought the Moroso 89560 last year and am very pleased with it.
    Sheboygan, WI
    Thumbs up EZ Air Gauge from Best Rest Products
    http://www.bestrestproducts.com/p-44-ez-air-gauge.aspx
    Spend $25 for this and your search is over.
    Good Luck.
