Results 1 to 5 of 5
Thread: BMW Panniers
    Registered User MOTOGP's Avatar
    Jun 2006
    Central Florida
    BMW Panniers
    Does anyone know if the hard panniers from a late model BMW interchange with others such as a set of panniers for a K1200S fit a R1200S? Obviously the hard mounting hardware is different, I am more concerned with the bags. I am in the market for a set to fit a R1200S model and have the opperatunity to purchase a set off a K1200S.
    Your wisdom on this matter will be greatly appreciated.
    Aug 2008
    Kingston, NH
    go to the max fiche website and compare the panneir part numbers to see if they are the same for what you are looking for.
    http://www.maxbmwmotorcycles.com/fiche/fiche.asp
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Jun 2006
    Central Florida
    Panniers
    Thanks for the link however there is no telling if there is a difference. The panniers for the K bike are called out as klugset while the r is called out as r12slug set. Both panniers look identical but there is no telling if the K1200S system will fit on the R1200S.
    Thank you for the response.............
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Quote Originally Posted by scottgp View Post
    If they have the same part number they are the same.
    R1200S Sports case: left 71607702873, right 71607702874
    K1200S Sports case: left 71607671401, right 71607671402
    So they are different. How different? Look at the parts that make up the case.
    R1200S: Case, bottom left: 71607702875, bottom right: 71607702876
    K1200S: Case, bottom left: 71607692063, bottom right: 71607692064
    well, there's a difference right there. The other difference is in the protective moldings.
    I found these differenced by bringing the same diagram up in two tabs of my browser and quickly switched back and forth to see what changed.
    // marc
    Jun 2006
    Central Florida
    Panniers
    Hey Mark,
    I greatly appreciate your efforts in determining this. I been watching a set of panniers on Ebay that were off a K1200S. Cant say they will be doing me any good. Trying to locate a used set for my R1200S has been a long drawn out process with no success. I hate the thought of dumping a grand for a set of bags.
    Will keep on looking until I just get tired of looking. Thanks again for your diligence in determining the K bags will not fit. You saved me a big headache!
