Results 1 to 8 of 8
Thread: Gas Tank Quick -connect
    SHEEPDOG
    Angry Gas Tank Quick -connect
    Well it is almost getting spring in Wyoming. Got my R1150 RT out of the barn yesterday and took a short ride. Parked in the drive way and seen a little gas on the right side under the center stand. Removed the right side and found the quick-connect leaking a little, touched the hoses and that was a mistake, lost all the gasoline, glad I was in the driveway got a can and saved most of the gas, Sure glad I at home, and engine wasn't hot could have been a bad thing all the gasoline hot engine.
    Ron
    Sep 2006
    what Spring's first ride is for! At least you can replace them with the upgraded metal ones now and take one less worrysome item off the list
    Steve Henson
    bflemingor
    That's been a problem with the K-bikes too. Dumped my "Q-connectors" at my 12K service, for brass barbs. A little extra hassel for O&R, but I don't worry about leaks 500 miles from the nearest shop.....
    ltljohn LTLJOHN's Avatar
    Jun 2005
    Haycock, PA
    Look here http://www.beemerboneyard.com/fuliqudise.html for a good quality replacement.
    USN Retired
    '02 R1150 RT
    On the Road
    Dec 2005
    West Seattle, the land that time forgot.
    I'll second the beemerboneyard QDs
    I've had the tank off half a dozen times in the past year, without any concerns. Remember to install one of the QDs "upside down" so when reconnecting them, there's no mistakes when snapping them together.
    SHEEPDOG
    Smile connects on order
    Got some brass connects on order. Sure is a week point the lines.
    TNX all
    Ron
    P Monk
    May 2005
    Port Neches, Texas
    mine broke 100 miles from nowhere
    hit a large hole at low speed and started leaking. Wasn't aware until i stopped and it was dripping to ground. Always carried fuel hose and connectors and clamps after that to eliminate the quick connects if necessary. Think that would be a must have like tire plugs and pump.
    P. Monk
    74 R90/6 (also know by bride as the Black Hole). 09 R1200 GS. My wife, 1953 model who has survived aplastic anemia and a bone marrow transplant.
    PELON
    I have a 95 R1100R, haven't had the bike long. do I have these? I haven't had the tank off, Should I just replace them?
