Results 1 to 11 of 11
Thread: radar detector
    Registered User theLuz's Avatar
    Dec 2003
    Glen Ivy, CA
    radar detector
    I just installed the motorcycle specific detector on the K1200GT. It looks cool and works very well.
    the Luz
    Dec 2003
    Glen Ivy, CA
    side view
    here is the side view of the unit
    the Luz
    Feb 2005
    New York
    Quote Originally Posted by theLuz View Post
    It does look really cool. What year GT do you have and color GT do you have?
    Nov 2005
    Calgary, Alberta
    Luz:
    Are you using helmet speakers with it, and do they work i.e. you can hear them over the wind noise?
    Rinty
    Dec 2003
    Glen Ivy, CA
    2007 K1200gt
    Pearl is a white 2007 that has 12,500 miles now. The wireless audio for the helmet works fine. The only problem is determining if it is actually on (if it's daylight). I've started re-starting the unit to make sure I can hear it cycle thorugh the different bands. It is very usable at speed.
    the Luz
    Dec 2003
    Glen Ivy, CA
    visual update
    I ordered the visual update and a car mount, but haven't used either, yet. I'll get home next week and try them out. I probably don't need the visual, but it's not that expensive and I like "belt and suspenders" approach.
    the Luz
    May 2005
    Corona Del Mar, California
    I'll bet with that K1200 GT you REALLY need that radar dectector, don't you?
    Dec 2003
    Glen Ivy, CA
    yup
    Quote Originally Posted by carockwell View Post
    yup
    the Luz
    I've had one mounted since July, 08. Easy to install. Flashing alert lights are visible in bright light. I use City NoX mode all the time in town and Highway mode only on the Interstates. In the twisties it doesn't matter because it can't see around curves. It senses being lit up from the rear, too. Occasionally convenient if you're not paying any attention to the mirrors.
    Notably, it is waterproof (the seller says water resistant) but I've had it in downpours and no apparent effect.
    Dec 2003
    Glen Ivy, CA
    Quote Originally Posted by laterider View Post
    I've had one mounted since July, 08. t.
    that's good to know, as I have just installed it. I'm going to use it in the car, as well, to get a handle on how it works. So far, I've left it in Highway mode, just to get it to go off more. I'll learn eventually. Thanks for the update.
    the Luz
    Dec 2003
    Glen Ivy, CA
    flashy thing
    I just installed the light flashy thing to go with the wireless audio update for the unit. I haven't ridden with it yet, but it looks cool.
    the Luz
