Results 1 to 4 of 4
Thread: Wilbers Shocks Height Adjustment
    honard
    I just opened my box of new Wilbers shocks. They look great, however the instructions are in German, and I only speak English (go figure!).
    I can install them and set them up ok, but there is nothing I can find that shows me how to adjust the height. I ordered them with the height adjustment option. Any help would be appreciated.
    Spring Lake NJ, USA
    Re: Wilbers Shocks Height Adjustment
    Not knowing which Wilbers you have.. I can only hazard a guess. Mine has a threaded bottom fitting mounted to the shock rod. There is a locknut above the fitting. To change the length you loosen the locknut and rotate the fitting.
    You could always ask Klaus if you bought them in the US.. (http://www.wilbersusa.com)
    honard
    I have the optional height adjustment feature, Option 629, without instructions. Hopefully Klaus is in tomorrow.
    honard
    Re: Re: Wilbers Shocks Height Adjustment
    Thanks, that did the trick.
