Results 1 to 7 of 7
Thread: Lowering R1150RT
    bmdubyou
    then theres the issue of shortening the side stand and center stands. I dont understand why beemers have to be so tall. one would think with the design of the engine that it would be able to be much shorter!
    CMH
    '98 RT, but I don't think there were changes to frame with 1150's.
    I lowered mine 1" with Wilbers shocks. In addition to the bike fitting my leg length/strength better, the shocks were built to match my weight and riding style. It made a huge difference in how the bike feels and how much easier parking and pushing back are now that I have more rande of motion with my feet on the pavement.
    I bought a used sidestand and had it cut. I use a floor jack rather than center stand, and it still goes under. The few times I need the center stand my neighbor gives me a hand, and it is a bear. But it's worth it to me. There are several chocks that you can use to park the bike upright, but I haven't noticed any problems keeping it on the side stand for extended periods.
    Every now and then if I brake hard and late in right hand 90's (intersections) the center stand scrapes, but if I finish braking and am on the gas, having less clearance isn't a problem. In the mountains I get close to the edges of the tires and nothing drags. The bike is capable of leaning farther, but I'm not. I bought an RT so I can sit up and see stuff, so lean angle isn't a big deal most of the time.
    Lowering my bike was worth the big bucks for Wilbers.
    Rick Swauger
    84 R65
    98 1100RT
    02 Kymco Cobra Racer
    Registered User Greg_K's Avatar
    Mar 2007
    Mechanicsburg, PA
    How much lower can you make the bike without modifying the stand? I was thinking about getting 1/2" shorter shocks myself. Of course, I'd have to lower the bike by 2" to flat foot it with my 28.5" inseam!
    I have a low Sargeant seat and haven't dropped my RT yet, but I have come mighty close.
    '04 R1150RT
    No matter where you go, there you are!
    Registered User bcusack's Avatar
    Mar 2008
    Blackstone, Ma
    [QUOTE=Rollifahrer;427271]'98 RT, but I don't think there were changes to frame with 1150's.
    When you cut your side stand did you get comcerned about the measurments or did you just take one inch off? I am about to add do the same to mine and I ask as with lower shorter shocks you are not lowering the bike lower to the ground as much as you are lowering the seat/upper frame relative to the swingarm. that does not translate to the same in ground clearance.
    Tiverton, RI
    Quote Originally Posted by bmdubyou View Post
    They have.. there are now a few models, R-1200-GS, R-1200-RT, a K-bike and a F modle all factory lowered. I sat on the lowered GS last sommer, Much more manageable that a stock GS for me.
    www.OceanStateBMWriders.com
    Northern Front Range, CO
    [QUOTE=bcusack;428967]
    Quote Originally Posted by Rollifahrer View Post
    shorter/lowered shocks will cause the entire bike to drop down. the wheels stay the same (obviously), but then EVERYTHING else comes down to meet the swingarm.
    to wit: at least 3 different length shocks have been offered on the R1100S, in combination with 2 different torque arm lengths (the shorter 365mm torque arm that comes on the GS will raise a R11S about an inch). 2 different length sidestands are also available to complement those different shock options.
    however, the 11S mounts the swingarm pivot differently than do the other models, and that "might" play into the situation... but i tend to doubt it. we went with the lowering links on my g/f's KLR, and had to slice about 2" off the sidestand to compensate for the drop in overall height.
    Ride Safe, Ride Lots
    CMH
    I marked the floor where the SS hit and had a friend hold the bike at the desired angle (~10 degrees). I pulled a string from the SS pivot to the center of the mark. The SS is bent, so I tried to compensate. Now that I think about it, I might have used some stiff wire to replicate the bend.)I had a 7/8" section cut out of the lower portion above the foot, as I didn't want to disturb the weld and reinforcement on the foot itself.
    I had the welder insert a solid rod to reinforce the weld. The SS is tapered a bit, so he filled and ground the step. I hit it with good primer and a couple coats of black enamel, making the mod. invisible.
    The back edge of the foot hits the floor now, leaving an 1/8" gap at the front. Not a problem for me, but take that into acount if you use a FatFoot. Not just the thickness, but also the width.
    I think cutting an inch would have been OK, but the string exercize gave me confidence before cutting up a good part.
    BTW: I highly recommend lowering front and rear equally for handling reasons. Lowering the front will most certainly lower the bike. The subframe is fixed relative to everything except the swingarm. When you shorten the shock (whether a shorter shock or compressing it under load) the swingarm angle changes and the frame (subframe/seat) gets closer to the ground. With proper compression and rebound adjustment the swingarm swings to absorb abrupt changes in the roadway, while the frame height relative to the road before and after the bump stays constant. (Sorry I strayed from the sidestand topic.)
    You might want to measure the lean angle when parked before removing the OEM shocks and match that angle. I didn't think ahead, but I'm happy with the results.
    I've said it in other threads, and I'll say it again: putting quality shocks on that bike can make a huge difference. Is it worth the money? Depends on what you care about.
    Rick Swauger
    84 R65
    98 1100RT
