Results 1 to 7 of 7
Thread: Helmet cleaning
    On the Road wack's Avatar
    RI
    Post Helmet cleaning
    I own a Shoei RF-900 and was trying to find info on how best to clean the interior padding. Does anyone know if the pads are removable. I sense they are but am hesitant to pull them completely out?!!? Any help would be apprecitated. Thanks in advance
    Loose Cannon flash412's Avatar
    Northern Colorado
    Put it rightside up in the dishwasher set to NO-HEAT DRY. Stand it up to dry outside in the sun. Stuff some newsprint in it to hasten drying if need be, change it every hour or two.
    RI
    Put the whole helmet in the dishwasher? I assume I would take the shield off. Does this deteriorate the shell in any way? Thanks for the tip
    Ritalin Poster Boy rob nye's Avatar
    Bristol, Rhode Island
    Yes remove the shield first.
    I have done this with my RF700's with great results.
    Works even better if you use a TINY amount of woolite.
    Good luck
    Rob Nye
    06 R1200GSADV 06 R1200RTP
    IBA 250 My Iron Butt Rally Blog
    Bristol, Rhode Island USA
    Proud to move oil
    Northern Colorado
    No. Just put the dirty bits in there.
    Yes, the whole thing. But no shield, just like Mr. Nye said.
    What's that noise...? basketcase's Avatar
    Alabama
    Another "clean the funky lid" trick is to take the helmet into the shower with you at your next appointed bath-time, and shampoo the inside of the lid vigorously. Rinse until you no longer get suds, and then do the "set it outside to dry" routine.
    If you happen to have any kind of electronic stuff in the helmet, (radio or intercom speakers, etc.) be sure and remove it first.
    As an aside, if you use a Sliks, or even a hanky tied into a doo-rag, it can forestall the intervals on the helmet cleaning. That is, if you wash the Sliks with some degree of regularity.
    Random
    If you use a shampoo like Clairol Herbal Essense your helmet smells really pretty.
