Results 1 to 6 of 6
Thread: $$$ questions -cost of rebuilding
    pete
    So basically here is where I'm at. I am going to rebuild my 75 r/90 after years of neglect. It does not need paint but I am planning on replacing many of the plated parts due to pitting. Here is the big list and this is what I am most interested in finding out as the small stuff can be replaced here and there.
    Big list =
    rebuilt motor
    speedo and tach
    set of spoked wheels
    complete stock exhaust
    I'll stop there....
    What can I expect to spend in order to get these things accomplished assuming I am installing all of the parts?
    Also I have a 2002tii which I am glad to say most everything is available for from the factory. How is availability for various and sundry parts?
    TIA
    Rally Rat gstom's Avatar
    Joplin, Missouri
    Rebuild Budget
    The big ticket items you have listed will probably run you $1500 or more. By the time you start doing other things "because I have it apart anyway" you will run up another few hundred, depending on how nice you want the finished bike. The toughest part about spiffing up a project bike is knowing when to say when and resisting the urge to end up with a show bike.
    The IBMWR Marketplace is an excellent source for finding good used parts at reasonable cost.
    Have fun with your project
    pete
    I hear ya
    Its easy to get carried away- That started to happen with my 2002tii but I have begun to find a balance about it. In this case I will not be repainting for that very reason. Just gettting the bike back into maintainable condition..... and that includes oxidation.
    Any recommendations on places to but a rebuilt engine?Looking at the Max BMW parts lists A new setup will run in the neighborhood of $3000. I'd rebuild myself but I am living in Japan can't find a good machine shop so everything would have to be shipped out- which is fine until something goes wrong- for that reason i am intertaining buying a completely rebuilt unit from a reputable source. I want it to be as good as a stock rebuild can be.
    Thanks,
    Pete
    dlearl476
    Re: $$$ questions -cost of rebuilding
    TIA
    I'm in the process of "freshening-up" a '70 /5. Just about everything is available from a dealer. Thanks to BMW's "Mobile Tradition" program, more and more parts are being reissued. In fact, I have yet to be stumped. Couldn't believe Irv Seaver had a license plate bracket IN STOCK!
    Google can be your friend. As can Ebay, although I'd surmise being in Japan might be a drawback as a lot of BMW parts aren't avalable for overseas shipment.
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    Pete, when I went through this process, I determined I needed to make the bike (a) workable (b) rideable and (c) pretty.
    You say you want a rebuilt motor. What's wrong with the engine now? Needs new valves, rings, bored and new pistons?
    Speedos can be rebuilt - mine was -- for a lot less than buying a new one. Tachs -- I'm not so sure.
    A complete stock exhaust will set you back some bucks. Are you adverse to aftermarket, or is this to be a full-on restoration?
    Don't you have spoked wheels now?? If not, maybe your can swap-out wheels.
    Sources include Bob's BMW, Motobins, the IBMWRA and BMWMOA classifieds, The Parts Haus in California, and Re-Psycle
    in Ohio, as well as the aforementioned eBay. And, have you looked at this site: http://www.bmw-motorrad.jp/
    Mac
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    And don't forget www.ibmwr.com classifieds! Also check at www.boxerworks.com for good how-to advice and also the BoxerWorks shop that runs that site may be of help.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
