Results 1 to 7 of 7
Thread: Gerbing‘«÷s Heated Glove Liners
    Hey Chromehead ! bobs98's Avatar
    Nov 2005
    Marlton, South Jersey
    Thumbs up Gerbing‘«÷s Heated Glove Liners
    I picked up a pair of these on Monday and did the install that afternoon. After freezing my fingers off riding home from work last Thursday, I stopped at DeSimone on Friday to check out heated gloves. I continue to ride when the roads are clear, but below 35 F or so, it can get a bit chilly on the finger tips, even for just a 40 minute ride. So I decided to investigate.
    I ‘«ˇm not really interested in the full heated gear setup with jacket liner, vest and/or pants, as my body doesn‘«÷t get that cold. But, gloves could be the answer for extended cold weather riding. I‘«÷ve looked before, but never with the intention to buy, and heated gloves were running in the $150-170 range. Alan, the parts manager, suggested that I look at the liners, which listed for only $79 and had better contact with the hands. He had only one pair of XXL, and he had been holding them for another customer since September. I told him I would check back on Monday, after the Big GIG, and to give the guy one cold chance to pick them up. The Gerbing‘«÷s booth at the show only had mediums (very poorly stocked), so I called for Alan on Saturday, his day off, and left a message.
    The glove liners come with the battery hookup, and wires long enough to run thru my jacket, between the liner and down the sleeves. I secured the wires using the snap fasteners of the lining. I also purchased an on/off switch for $15 instead of the $70 thermostat controller. If I was getting the full setup, I probably would splurge for the controller.
    Installation was easy, and I removed the tank for the second time in a month. (I will be purchasing Quick Disconnects from Beemer Boneyard soon.) Positive and negative wires to the terminals, run the plug end out to the left side and secure with a couple of zip ties. Put it all back together, only took about 30 minutes, and did a test fire after dinner. It worked! Word of caution: Start the bike before connecting and turning on the heat. Turn off the heat before turning off the bike.
    This morning I got to do the real test. Temp on the deck registered 19 F, 17 in Philly, and a forecast high of 26 for the day. Rolled the bike out of the garage and it fired right up with the new PC 680. Plugged in and turned on the liners, with Olympia Windtex gloves as outer layer. I could feel the warmth in less than 3 minutes, and had a toasty ride in to work at 7 am.
    My winter combo is now complete. I got the correct size First Gear HT II Overpants with liner (arrived yesterday), First Gear Jaunt jacket with liner, Gerbing‘«÷s heated glove liners under Olympia Windtex gloves, and Nolan flip face helmet. I am looking forward to a longer ride this weekend to give an extended test, but think these heated glove liners are fantastic!
    Here's the info from the Gerbing's site:
    heated glove liner $79.95
    ?? Form fitting stretch cordura fabric allows for a snug fit as these gloves are designed to be worn under existing gloves or mitts.
    ?? Recommended for use with un-insulated riding gloves.
    ?? Utilizes our patented Microwire?ę heating technology ‘«Ų the most efficient and durable heating technology ever developed.
    ?? Heats entire length of each finger, including the thumb, as well as the back of the hand
    ?? Adjustable Neoprene cuff
    Specifications
    Heat Microwire?ę
    Source 12-volts DC
    Current 2.2 amps
    Watts 27 watts
    Surface Temp 135??F +/- 5??F at 32??F
    Bob Smith
    1998 R1200C
    2005 Rocket III
    BeemerBoy terham's Avatar
    Feb 2005
    Exit 31, PA TPK
    I wish I had known about glove liners before I bought the gloves and thermostat. I love the gloves (G3) I bought this fall but didn't realize there was a cheaper alternative.
    Won't need the liners on Friday Bob. Supposedly will be in the 40s.
    Terence
    R75/5 R100RS K100RS R1150RT
    My Smugmug
    Nov 2005
    Quote Originally Posted by terham View Post
    Ride Saturday?
    Bob Smith
    1998 R1200C
    2005 Rocket III
    RK Ryder
    London, Ontario
    Not meaning to hijack this thread but I've been riding for two seasons with the Gerbings gloves. Only once have my hands gotten cold, never, never, never toasty. The one time the hands did get cold, the temp was about 38F. In fact it seems that I really never feel the heat from the gloves but the hands do not get cold other than one ride last November. Is this normal or do the gloves get really warm for everyone else? I do have a thermostat for both the gloves and jacket, but I never make any adjustments for the gloves. I have even switched the glove and jacket plugs into each other's circuit but that still made no difference.
    Paul
    Knights of the Roundel #333
    Feb 2005
    Exit 31, PA TPK
    Quote Originally Posted by bobs98 View Post
    Ride Saturday?
    PM sent.
    Terence
    My Smugmug
    Nov 2005
    Update
    Well, it's been a week. I have ridden with the heated glove liners five days, including a couple of short runs up the interstate in sub freezing temps. These liners are amazing! When worn under my Olympia Wind Tex gloves, my hands are very warm. Gerbing's does recommend wearing a non-insulated glove over them, and perhaps they would not be quite so warm with less on top. Toasty is much better than frozen!
    I am very happy with them!
    Bob Smith
    1998 R1200C
    2005 Rocket III
    Registered User Hawkinsjm's Avatar
    Jan 2008
    Charlottesville, Virginia (My heart lives in Charleston, SC)
    Tried and failed.
    I tried the liners with my Gerbings heated jacket and I don't know if the extra draw of wattage made a difference (I ride a F800ST), but I didn't experience toasty heated experience others attest to have had. I ride in Central Virginia near the Blue Ridge on clear days and the temperature will often be in the twenties with wind chill.
    The liners let me down. In my testing, my finger tips would get the usual ice treatment and the back of my hands would only be kept lukewarm. When I would come to stops I'd get the toasty feeling, but only on the backs. I still had to employ my heated grips.
    I took the liners back and now have some of the FirstGear Carbon heated gloves on order. Review that I've read give them very high credits.
