Results 1 to 11 of 11
Thread: Tools-Cordless Screwdriver
    beemergrl
    My husband's B-Day is in a couple of weeks and I thought I would get him a cordless screwdriver and bits, etc. to work on the bike. I am tired of the allen wrenches. It is time for them to be replaced with something faster. Anyways, can someone comment on what you are using to repair your bike with. I am looking for a cordless screwdriver and some metric tools to go with it. Any opinions will be appreciated. Thanks.
    I received as a gift one of the B&D with the new battery technology. However, it is shaped like a pistol, it's a bit fat and hardly reaches into anywhere. I wish I'd been given one that has the pivot point, so it can swing into a straight handle, and I wish it was a bit smaller in diameter, so it would fit more places. But, on the good side, it came with a bazillion little inserts.
    Registered User godfather's Avatar
    Oct 2006
    Cadillac, MI area
    I have a Craftsman, with the pivot, that I bought a few years ago. I have used countless times without fail. It will make small work of removing 30+ tupperware screws. I always used an allen wrench to put them back though.
    Attitude is everything!
    1978 R100/7
    08' V-Strom 650 great light weight tourer
    grumpyone
    Black and Decker
    Black and Decker makes a small piviot type ; Can use it as a pistol for leverage and straight for speed.
    It is rechargeable and runs about 25 bucks. Pretty handy if you have a lot of tuperware to take off but like mentioned above dont use it to put the tup back on; It will spin up and brake the hole out been there done that.
    If you need another handy idea if he does not have it get him a tap and die of the tupperware size to chase the threads when needed ; comes in real handy cleaning up misaligning screws that get cross threaded.
    Good Luck ; Sounds like anything you get him would be appreciated, its the thought right
    Jim and Esther
    #13338 PGlaves's Avatar
    I have a Skil shaped approximately like a 2 cell flashlight with a removable battery which fits in a charger. I have 2 batteries. That way if I run down the other is charged up ready to go. It has a rocker switch to operate with your thumb: press left; counterclockwise - loosen. Press right; clockwise - tighten.
    I use it all the time. I have adapters for 1/2", 3/8", and 1/4" drive sockets. So can use any of my sockets, socket allen wrenches, socket ball end allen wrenches, etc. And of course screwdriver and Torx bits. I use it on fasteners ranging from body panel screws to wheel bolts (once loosened of course).
    Registered User bluegrasspicker's Avatar
    Aug 2006
    MN
    Quote Originally Posted by beemergrl View Post
    This Bosch is fantastic. Happy Birthday to him!
    http://www.amazon.com/Bosch-PS20-2A-...8C2SQWZ56ES2ZM
    Va Bch VA
    +1 on the Bosch!
    Now somebody convince my wife that one of these would compliment my Dewalt battery drill/driver collection.
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    cordless screwdrivers
    Is this a new idea?
    I just went out to check my toolbox and EVERY screwdriver in there is lacking a cord. Same for all my wrenches and hammers too!
    Does this mean for once I am finally ahead of the technology curve?????
    Friedle
    Airhead #46
    Ride fast safely
    beemergrl
    Thanks everyone for posting some suggestions for tools. I knew that I could come and get some great information from all of you. Thanks for posting and sharing.
    Penforhire
    Just a thought, I almost never use electric or air tools on my bikes. For faster Allen bolt wrenching I highly recommend a high-quality "T" handle set instead.
    Jul 2007
    THE BIG SKY
    Aw come on, it's his birthday! Why not spring for something a bit more elaborate.... he deserves it does he not?
    Kevin Huddy
    Tm Pterodactyl MT Outpost
