Results 1 to 7 of 7
Thread: Upgrading Electr. Charging System?
    On the Road
    Jul 2004
    JONESBORO, AR
    Lightbulb Upgrading Electr. Charging System?
    I WANT TO BEEF UP THE WATTAGE OUTPUT ON MY 93 R100PD. I HAVE SEEN THE COMPLETE KIT THAT MOTORAD ELEC. SELLS FOR AROUND $575. IT INCLUDES A NEW ROTOR, STATOR, VOLTAGE REG., DIODE BORAD SOME OTHER ITEMS. DOES ANYONE KNOW OF OR HAVE A MORE ECONOMICAL SOLUTION. I BELIEVE AFTER TESTING THAT MY CURRENT ROTOR IS BAD BUT I WANT TO BE ABLE TO SUPPLY SEVERAL ACCESORIES AND THE CURRENT 250 WATT @ 4000 RPMS WILL NOT DO IT.
    Registered User R100RS's Avatar
    Jul 2003
    North Florida
    What exactly are you trying to power? The stock alternator puts out 280W.
    The MotoElectrik is by far and away the best solution to increasing the alternator output of an airhead. The only other alternative I've ever heard about is mounting a car alternator (Saturn?) outboard of the engine. This required a lot of custom work to do.
    I don't run any accessories, but the two best improvements I made to my eletrical system was upgrading the voltage regulator to the police model and replacing the wet cell battery with a gel/AGM battery (Panasonic sealed battery). The sealed battery doesn't discharge as quickly when not being used (I can easily start the bike even after it's been sitting for a week or two in winter). The police model voltage regulator starts battery charging at around 1500 rpm instead of the standard regulator's 3500 rpm or so. So, my battery actually gets charged on the 4 mile stop and go commute to work.
    P.S. - please turn off your caps lock. All caps on message forums is the same as yelling.
    -Mike
    '02 R1150R
    '88 R100RS
    On the Road
    Jul 2004
    JONESBORO, AR
    Sorry about the caps-old habit. I added a set of moto lights, GPS, and I have been running an XM reciever. If I turn on my grips and run my vest....! Well you get the picture. More than anything, since I am gonna have to replace the rotor anyhow I thought I would just go ahead and overkill the system.
    The police voltage regulator might do enough however to solve my "slow drain that seems to take place after several hours of riding. It is usually the lower RPM gravel roads and switch backs that get me.
    Do you have a part number or any reference for the police voltage regulator? Thanks for your help.
    Kevin
    Jul 2003
    North Florida
    Hmmm, that does sound like quite a bit of load. Especially if you're running the lights and heated grips/vest at the same time. You'd have to do the math and add up the wattage of everything you're using and see if the upgraded alternator kit is worth it to you.
    I don't know the part number for the police VR. Eurotechmotorsports has them and that's where I bought mine.
    -Mike
    '02 R1150R
    '88 R100RS
    Rbike
    The regulator will not solve all of your charging problems...it is a good item to use for a lot of slow off road riding. You should also consider puting a switch in line with the headlight so you can turn it off while you're off road. It's cheaper than the regulator and can come in handy if your alternator quits.
    A friend put on the high output alternator kit a year ago when his rotor failed and hasn't had any problems.
    On the Road
    Jul 2004
    JONESBORO, AR
    I found the police regulator at Eurotech. I think at least for now I will try to use the higher drain items sparingly and see if the new regulator will at least help as my battery seems to stay charged as long as the rpms are up.
    Just puttsin' OldNuke's Avatar
    May 2004
    Minnesota
    Have the Omega system from Motorrad Elec. in my 90 GSPD and it works as advertised. The original system just doesn't cut it, especially riding around town and in other low rpm situations with a sizeable load on the system. At the National in Spokane I also saw a charging system of significant wattage mounted on I believe an R80GS or maybe an ST. Well anyways, the system did away with the BMW rotor,stator,diode board,etc. A pulley was mounted where the original alternator used to be and a vbelt from there drove an alternator mounted in the area at and behind the original diode board location. The owner had a spare vbelt hanging on the with a tag saying the "only spare part needed". Here's the name and #'s I got off the bike:
    Greg Hutchison
    415-205-7829
    ghutchin@pacbell.net
    When you come to a fork in the road, take it.
