Results 1 to 8 of 8
Thread: Atlantis 4 Leathers
    Jul 2008
    Itasca, IL
    Atlantis 4 Leathers
    I'm thinking about buying either the Atlantis 4 or 3 jacket and pants. How do you like them? Is it worth the addional $ to buy the 4 over the 3?
    Registered User theLuz's Avatar
    Dec 2003
    Glen Ivy, CA
    I don't think they changed anything
    I don't think they have (essentially) changed anything on the Atlantis since the Atlantis I. I have the original and the only thing I could say that was diffeent is buttons you can attach suspenders to the pants. You will need suspenders, as the pants are very heavy, but the clamp on braces are fine.
    You'll love the suit and it really looks good on or off the bike. I bought one several years ago (and, of course had to buy another for the wife). I get compliments on the suit almost every time I wear it, which is most of the time I ride. We call it our "Armani" and it certainly cost like it.
    Good luck.
    the Luz
    Ute's Chauffeur
    Sep 2006
    Central NY
    Don't have one but the 4 is waterproof without liners. i believe it is due to a laminated leather/waterproof membrane material
    criminaldesign
    Stone Lake Leather
    I picked up a pair of Stone Lakes leather bibs.
    Dan is great to deal with, tailored to your size, heavy freaking leather (optional), and good looking. Makes a fine match with the leather jacket.
    Smooth lining so they glide over clothing, pockets galore and solid hardware. These are not cheap but will last forever. Quality homegrown product.
    My 2 cents of what else is out there. safe riding. houston
    Dec 2003
    Glen Ivy, CA
    atlantis
    Quote Originally Posted by cruisincruzan View Post
    all of the series are waterproof from the very begining. I was told that you can wash it 3 or 4 times (need to retreat the leather with BMW treatment stuff) and after that, you can send it to them and they will professionally re-treat the leather. These are truely lifetime garments. You'll love the suit. By the way, I've had the suit over 5 years and I haven't needed to wash it, yet.
    By the way, these are good for cold weather, but surprisingly comfortable up to and slightly over 100 degrees (as long as you're moving). Good luck.
    the Luz
    Ute's Chauffeur
    Sep 2006
    Central NY
    My understanding is that the leather is water repellent via some type of treatment but the Atlantis 3 had optional gore-tex liners to make it waterproof (although the leather itself could get wet depending on the level of water repellent left in the leather). The 4 has a permanent waterproof liner laminated to the leather that makes it waterproof all the time. The water repellent aspect of the leather is similar to the 3. The advantage of the laminated liner is that it is less "blousy" than a zip in liner and the leather tends to get less wet and dry quicker. It is similar in concept to the Rukka Lancelot and Aerostich Transit. I do like the nubuk type leather.
    Dec 2003
    Glen Ivy, CA
    good information
    If that's true, the "4" would be less usefull in warmer climates. That's the big knock of the Aerostich overalls, they're hot. I'd go for the Atlantis 3 or earlier, if he's correct.
    the Luz
    Ute's Chauffeur
    Sep 2006
    Central NY
    Agree on the problem in hot weather. I have the BMW SG2 suit which has laminated Armacor (laminated with Gore-Tex XCR supposedly the most breathable of the various types of Gore-Tex. When it's really hot that breathability means squat. Waterproof and breathable are pretty much mutually exclusive terms.) I haven't seen the Atlantis 4 suit but the Rukka and Aerostitch leathers are perforated (smaller perforations than the perforations on a typical perforated jacket like a Vanson) which adds a level of air movement while still remaining waterproof. Good Luck in your search. Whatever you I would be interested in your impressions.
