Results 1 to 3 of 3
Thread: Accessory outlet K1200GT 08
    Registered User northsquad's Avatar
    Jul 2007
    Long Island, New York
    Has anyone added a accessory plug outlet to a new GT? Does the side tupperware need to come off, or can the wires be fished from the Battery to the accessory panel?
    MOA Member #106320A
    2003 R1150RT Silver
    2008 K1200GT Dark Graphite
    old fa_t 110593's Avatar
    Nov 2006
    Boerne, TX
    outlet for the GT
    Yes you can do it. Have a wire (stiff) fished through then attach the outlet wire and go for it. Joe
    J Fisher
    R1200RT
    R1200GS
    Registered User theLuz's Avatar
    Dec 2003
    Glen Ivy, CA
    wire directly to the battery
    when you do the addition, wire it directly to the battery in order to have use when the ignition is off. That way you can use the normal battery tender and use the power for your tire pump or whatever. The outlet that comes with your bike cuts off seconds after the ignition is shut down.
    the Luz
