Results 1 to 13 of 13
Thread: Zumo 550 -- 2009 Map Upgrade?????
    Registered User westhautianplen's Avatar
    Apr 2007
    Terre Haute
    Before I invest the $69.00 for the 2009 map upgrade for the Zumo 550 I was hoping someone could let me know if you felt it was worth it and what differences you might have noticed. I am not sure which version I have, but I have experienced that some towns that I drove through in Iowa this summer really confused it.
    Plen Smith
    07 R1200RT
    Kimberton,Pa.
    Bought a new Zumo 550 before the Gillette Rally which had the '09 maps. Gas stations( no longer in existence) where the main issue that I had..especially out in the middle of no where...
    Sep 2006
    Here is a link to the Zumo Forum...lot's of Q&A's
    http://www.zumoforums.com/
    Have always had issues with some of the gas stations locations...either NOT listed as in 3 miles away and it sends you 30, or as you say the station is closed...that part is not in their control so much
    I actually was able to download my '08 update for free from the Garmin ZUMO site right after calling tech support for a unlock code issue. Thye next time I looked at site, it was available for a two day period for FREE. Have not looked at Forum in awhile...might have some good info
    Steve Henson
    Rally Rat PAULBACH's Avatar
    Dec 2005
    Quote Originally Posted by Plen View Post
    The first map update on my ZUMO was free. Hook your ZUMO to your computer and it will let you know. Updates to the operating system are always free.
    Oh Best Buy was selling a Garmin update for $58.
    Apr 2007
    Terre Haute
    Zumo Update
    I was updating the operating software yesterday and was made aware of the 2009 map. I will check best buy. Thanks for the help.
    Plen Smith
    07 R1200RT
    Aug 2008
    Kingston, NH
    i usually update on every other update - a little cheaper and get more of an update.
    The interface for mapsource has been modified - some like it others don't - i think it is ok
    Follow up on the Zumo forum link - great information there
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Registered User stkmkt1's Avatar
    Sep 2008
    Tremont, IL
    A bit off topic, but do you all know that if you find an area where the GPS map is incorrect, or roads missing, you can let NAVTEC know and they will come map the area? Go to NAVTEC Web site and you will find a way to let them know where they need to map. Then they will send out a car to map the area and get it into the software. They also have a kinda cool video you can watch that shows you how the actual mapping takes place.
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    Plen.
    I bought the 2009 map update and it loaded just fine to my Zumo 550. As to what the benefit is, I'm guessing it takes into account new roads that previously weren't complete on the prior maps or perhaps things like new hotels and businesses. A few years ago while using my older Garmin 276 I was heading to a Comfort Inn in Asheville, NC to spend the night. After arriving there tired and doing a series of U-turns since I was having trouble locating it, it turned out it had changed hands and became a new brand. I think a Sheraton or a Ramada. My guess is if you keep using your existing 2008 maps you most likely won't run into any issues. After all, most major roads don't change. I just thought it would be good to have more current data. I'm guessing much of the changes have to do with changing of businesses , hotels, or additional points of interest. Just a guess, but it works just fine.
    Almost famous firebird's Avatar
    Feb 2006
    Maryland
    I've upgraded and it's fine. Some improvement on a couple functions, but I lost the ability to use my Motorrola bluetooth ear piece with it when I use my Zumo in my car.
    Recycling saves the Planet. Peace saves lives.
    '05 BMW F650cs
    MOA, BMWBMW, BMWRA, AMA, Black Belt Gang,
    MSF, Rider's Edge instructor IBA#35617
    AZ
    Quote Originally Posted by Firebird View Post
    The use of bluetooth would be controlled by the OS, not the map software. You should double check your configuration settings.
    MOA #107139
    RA #28511
    YB #2005
    Tiverton, RI
    Quote Originally Posted by BMWPhreak View Post
    Yep that sounds right. Are you going to the meeting Monday??
    www.OceanStateBMWriders.com
    Danger: Keep Back 500 Ft FredRydr's Avatar
    Jul 2005
    central Pennsylvania, USA
    There are so many changes and additions and deletions every year all across North America that $69 sure doesn't seem like much. I would think the value of the update depends on how much travel you do. If you are always riding in the same area or on the same roads, then it might not be worth it.
    Fred
    Registered User rmarkr's Avatar
    Mar 2007
    Lowcountry
    I recent installed an XM antenna (Xmas present). A week or two ago, rolling down the road, I got a message that a bluetooth driver was being installed onto my Zumo. All BT communications were lost (phone and headset) but were easily retored by initiating the pairing routine. My question is how was this data transmitted and received - the satellite receiver?
    Mark
    "Of all the things I've lost, I miss my mind the most" Mark Twain
