Results 16 to 30 of 42
Thread: Helmet Smell
  1. #16
    BFish
    every now and then i pop one those things you put in a drier that makes clothes smell nice and fresh. leave it over night and it helps.
  2. #17
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Quote Originally Posted by Paul_F View Post
    I use a Sliks liner.
    +1
    No helmet funk and they help with helmet fatigue on long rides, as well.
    I think cyclegadgets.com carries them and they are not expensive . . . 15 - 20 bucks?
  3. #18
    DavidBMWRT
    "Fabreze"
    spray with "Fabreze".......... works very well for me
    I don't recommend it but I have washed mine in a bucket of soapy water and then rinsed with a hose. I let it dry out side for a couple of days.
    it was either this or throw it away....... worked very well.
    My brother puts his in the dish washer. He said it did not hurt it. I have done this to ball caps with success but I don't know about plastic helmets.
    The Fabreze is a sure thing if it hasn't gone to far.........
  4. #19
    Scottish Transplant Picinisco's Avatar
    Mar 2007
    The Desert Southwest, AZ
    I have read various suggestions elsewhere from taking your helmet in the shower with you and using shampoo to putting it in the dishwasher or filling the sink and using dish soap or using woolite and a garden hose. I guess there are some really funky helmets out there.
    2004 R1150GS 1978 R75G/S Frankenbike
    AMA - BMWMOA - BMWRSOC - AZBEEMERS
    Gilbert, Arizona
  5. #20
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Shampoo works pretty well- the idea being that if it can get the stuff off your hair, then it can get the same stuff out of the fabric in the helmet. I noticed that the original poster lives in Arizona, so drying shouldn't be major issue.
    That said, I *really* like removable, washable padding.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
  6. #21
    Urbana, IL
    I soak a hand towel with alcohol and scrub the helmet out with it about every couple of weeks or sooner. Stays nice and fresh.
    My other bike is a BMW.
  7. #22
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    I strip the intercom wiring out of my helmets, pull the removeable parts and wash everything thoroughly in sunlight liquid dish soap and warm water. Then rinse everything with lots of fresh water and pat dry as possible with bath towels. A small fan applied to all the parts overnight and the helmet can be reassembled. I do that twice a year on every helmet I've ever owned. Makes the foam last much longer and feels like you bought a new helmet every time
    PS - don't forget to scrub the chinstrap too!
    Ufda happens..........
  8. 11-28-2008, 06:37 AM
  9. #23
    wsteinborn
    (1) Helmet line is great
    (2) Wash or replace the pads. Your "fit" will be better, too. Usually.
  10. #24
    Registered User bterhune's Avatar
    Shelbyville, Ky.
    when I need to air my helmet out. I just do that. place on the patio in sun for a few hours seems to work for me
    Bridwell Terhune
    Patriot Guard Rider#124388
    BMWMOA#102726
    bterhune@dcr.net
  11. #25
    Sep 2006
    Canon City Colorado
    Handywipes
    Try putting a handywipe type cloth/paper on top of your head or in your helmet when you put it on. It'll smell better and do a little cleaning while you ride.
    gpodzo
  12. #26
    Mongo
    For me, I found the cure the same for both my boots and my helmets. Have 2 sets and alternate them. It gives them a chance to dry out between uses. After long trips, I'll put the helmet I used on the trip on the shelf for a bit and use my alternate.
  13. #27
    Registered User MOTOR31's Avatar
    Aug 2006
    Full timr RV'er, where we park is home. No fixed address or location.
    Be careful of what you put in or spray on your helmet. Make sure it won't degrade the interior materials like the foam, both hard and soft, or the helmet will not be as effective as i should be.
    DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
    Author Unknown
  14. #28
    Mar 2007
    Calera, Alabama
    1. Use an absorbent towel and blot inside after each ride.
    2. Leave shield open if you set it on a flat surface to allow air flow.
    3. Use a foam helmet cleaner before you ride if it needs it.
    4. Remove and wash liner every week or so if needed to get it really clean.
    5. Never use any petro chemicals. Styrofoam doesn't like it.
    6. Warm air promotes bacteria growth. Put it in freezer if possible or a cold garage in winter to retard or kill bacteria growth.
    7. Carry a terry cloth towel to dry your head at stops if you don't already. Less sweat means less work later.
  15. #29
    Mar 2007
    Make up a baking soda solution, with about a cup of soda in a gallon of water. Pour into upside down helmet and let soak about 30 minutes. Then pour in about a cup of vinegar. Let sit until the foaming stops. Then rinse and dry out.
  16. #30
    Registered User 37071's Avatar
    May 2004
    Petrolia ON
    Shampoo
    A Shoui helmet I owned years ago came with a recommendation to wash out the inside with what ever shampoo you normally use. Shampoo isn't too harsh. It definately helps to remove/reduce the funk.
    Gar
