Results 1 to 15 of 19
Thread: Supplemental LED Brake Light
    DanRT02
    I ordered the Supplemental LED Brake Light that is in the BMW Motorrad Accessory catalog. See pic.
    http://www.frappr.com/?a=viewphoto&i...741&myphotos=1
    Not having this yet, can someone tell me how thay get installed and how it get wired.
    Registered User Beemer01's Avatar
    Mar 2007
    Chicago, Ill
    LED Brake lights
    I have the Hyper Lights - there is a small control unit which is tucked away in the rear storage unit... otherwise you just tap into the existing brake wiring. 30 minute job on mine.
    Mine uses a different harness, but as far as the physical install (should be close to mine), the mounting plate matches up to the license plate mounting holes on the rear fender, generally you'll connect the light to the harness behind the license plate. This also means, that each time you take the license plate off the light is partially "uninstalled".
    The harness probably connects up under the rear seat, but I haven't installed one on a R11xx. I installed mine in 30 or so too.
    -Joel
    DanRT02
    Thanks, I was hoping I wouldn't have to tap into the OEM wiring. I'd like to do a plug-n-play type of installation. I'll have to get this some thought.
    Mar 2007
    Chicago, Ill
    OE Wiring
    This is where the signal and power for new lights originates. The link you set up clearly shows tap connectors.
    Piece of cake, even for an electrical moron like me.
    DanRT02
    Thanks Beemer01.
    I may not have been clear before. The add-on LED harness should connect to the LED unit behind the plate. Like Beemer01 said, you still need to either tap the LED harness into the factory harness, the harness may have a connector (I've seen a 2006 harness w/one) or fabricate a Y connection.
    The kit shows scotch-lock taps which I have seen corrode over time, so you may want to consider an alternative connector. Guess you'll find out for sure when it shows up.
    Tigard, OR
    Quote Originally Posted by DanRT02 View Post
    I installed one on an 1150RT. Wired it directly to the brake light using piggy back connectors. The piggy back connectors plug in place of the existing brake wires and provide two connector (like a Y) to plug the original wire and the new LED wire. No splicing or tapping.
    I got the connectors from the BMW mechanic at my local shop when I picked up the light. You will need three.
    Takes about 30 minutes including removal of the brake light cover.
    Chris
    2010 1200RT
    DanRT02
    Y pig tail
    The Y connector is what I would like to have for the brake light. Thanks, I'll be at a local shop tomorrow and I'll ask about these.
    I make a Y conncector for my GoldWing when I added a second horn. It's a clean installation. I wasn't sure if this could be done for a add on brake light.
    Coffee is 99% water CoffeeGuy's Avatar
    Oct 2007
    St. Louis, MO
    I installed a Brake! LED light in my r1100s, took less than 5 minutes. The company is back up here. I highly recommend, based on my experience. YMMV.
    DanRT02
    Thanks coffeeguy, I'll add the addition brake light that I now have but may look at this modulator as another option.
    DanRT02
    I have two problems. I didn't receive direction with the Supplement LED Brake Light. There is a white with a yellow strip wire and a white with a dark gray strip wire and I'm not sure where they connect to the bikes brake light wiring. Can someone tell me where these wires go?
    Chris wrote "...Wired it directly to the brake light using piggy back connectors. The piggy back connectors plug in place of the existing brake wires and provide two connector (like a Y) to plug the original wire and the new LED wire" Does anyone know where I can get one of these piggy back connectors, I'll need three.
    workin' them angels indycar's Avatar
    Nov 2008
    Muncie, IN
    Can't help with the install, but for those of you who have already added rear lights, would you post of pic of it, as it sounds like everyone is using a different type/brand.
    I'd like to see what my options are before i buy one.
    2006 R1200RT 1982 CB900F (Honda)
    "Mr. Treehorn treats objects like woman, man."
    DanRT02
    Y connectors are a piece of cake
    Chris, I took the light assembly off and I see what your talking about. There are two blade connectors on the light bulb base and Y connectors are very easy to use for this type of hook up. Thanks, I should have taken the light assy off the bike when I first posted about this light.
    Quote Originally Posted by indycar View Post
    Hmmm, I'm sure I posted a pic and a link to my Brake! install but since it isn't here I guess I forgot to do a "submit" after a preview. Or "they" are out to get me by screwing with my mind.
    Anyway, take a look at http://www.snafu.org/pics/r1200gs/brake/ to see how the Brake! looks installed on my R12GS.
    // marc
