Results 1 to 6 of 6
Thread: denier numbers?
    The Blue Max 31310's Avatar
    Apr 2008
    Calgary Alberta
    denier numbers?
    What is meant by the denier numbers for cordura etc? Is a higher number indicative of better quality or the other way round and does it apply to gore tex jackets?
    Jul 2007
    THE BIG SKY
    More is Better Mostly
    Denier is a unit of measure for the linear mass density of fibers. It is defined as the mass in grams per 9,000 metres. In the International System of Units the tex is used instead (see below).
    One can distinguish between Filament and Total denier. Both are defined as above but the first only relates to a single filament of fiber (also commonly known as Denier per Filament or D.P.F) whereas the second relates to an agglomeration of filaments.
    The following relationship applies to straight, uniform filaments:
    D.P.F. = Total Denier / Quantity of Uniform Filaments
    The denier system of measurement is used on two and single filament fibers. Some common calculations are as follows:
    1 denier = 1 gram per 9 000 meters
    = 0.05 grams per 450 meters (1/20 of above)
    * A fiber is generally considered a microfiber if it is 1 denier or less.
    * A 1-denier polyester fiber has a diameter of about 10 micrometres.
    * Denier is used as the measure of density of weave in tights and pantyhose, which defines their opaqueness.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Geeeeeeeeek. andrewsi's Avatar
    Nov 2008
    Near Seattle
    A hopefully somewhat more straightforward answer:
    Higher denier = "better." I believe that higher numbers indicate heavier/denser fabric, and presumably better abrasion and wear resistance, thus better protection in a crash without wearing through to the layers underneath.
    Andy
    2009 R1200 RT
    Apologies to all, but I can't help posting this:
    A plumber emailed the National Institute of Science and Technology saying that he had just heard that hydrochloric acid would clean clogged drainpipes and asking if it would be safe to use.
    The expert at the Institute emailed back saying: ǣWhile the efficacy of hydrochloric acid as a solvent is indisputable, the corrosive impact of ionic residues is incompatible with metallic longevity. Consequently, its use is contraindicated for your proposed application.
    The plumber emailed back thanking the Institute for their response, but asked it they would just tell him how long it would take to clear the pipes. In frustration, his problem was handed off to a lower-tier expert who emailed the plumber: "While, as you have observed, hydrochloric acid is undeniably highly effective as a reducing agent in removing drainpipe obstructions, we must point out that its caustic properties are likely to have highly foreseeable adverse consequences in its chemical reaction with ferrous metals.
    Once again, the grateful plumber wrote the Institute thanking them, and telling them that he was going to give the hydrochloric acid a shot.
    In response, one of the NIST lawyers wrote the plumber saying: ǣThe NTIS must inform you that while the use of industrial grade hydrochloric acid on bathroom sewer pipes will clear obstructions, the production of toxic, noxious, and corrosive agents is unavoidable.
    The plumber sent another email to thank the conscientious folks at the Institute. He said that because of their technical advice he would recommend that all his clients regularly use hydrochloric acid to prevent clogged drains.
    Finally, that night, a cleaning lady who happened to read the correspondence on an NIST computer screen wrote back: ǣSTOP using hydrochloric acid! It eats the hell out of metal pipes.
    Registered User bobmorse's Avatar
    Aug 2004
    Massachusetts
    Cool
    Quote Originally Posted by airoilheadbeemerguy View Post
    IN GENERAL, although this is not the technical definition, .....For a given type of fabric (Polyester, Cordura nylon, etc), the larger the denier, the larger the yarn. A 1,000 denier yarn is larger (courser, heavier) than a 500 denier yarn. Fabrics made of 75 denier yarns would typically be used for very lightweight tents or jacket linings. Fabrics made of 500 denier yarns would be more commonly found in backpacks or motorcycle jackets.
    Denier is not a measurement of quality, just (effectively) yarn size. What material the yarn is made from (polyester, nylon, Cordura nylon), how many filaments (strands) are in the yarn, how the yarn is woven (plain, oxford, taffeta, ripstop), and of course fitness for your purpose, contribute to the "quality."
    Gore-Tex is a coating related to Teflon; not associated with any denier.
    Quality in a garment is a combination of correct choice of fabric for the application, the design of the garment, and the actual construction of the garment (taped seams? quality of zippers? lined?)
    Many variables, many choices.
    /Bob
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    RE: plumber story
    I can relate! I once had to figure out how to wire a six-pole pressure switch for which I had no documentation and called the manufacturer about it...they had me talk to an engineer who took 15 minutes to describe how each throw and pole is affected by changes in pressure. I had to draw diagrams to follow along with hiw descriptions, and I still only barely got it- and I'm a technical guy! A simple "this pole and this pole open above 60 psi, and this pole and this pole open below 40 psi" would have sufficed.
    I have grown to really despise engineers.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
