Results 1 to 4 of 4
Thread: zuno 550 Battery
    Registered User 37071's Avatar
    May 2004
    Petrolia ON
    zuno 550 Battery
    My zumo went dead Monday; happily at a non critical time. I called Garmin and talked to a nice person without any waiting.
    I was told that it was likely the battery. When 1 cell goes dead then the unit will not activate. I followed instructions and got the unit to work on the AC charger. Garmin is sending me a new battery on warrantee. I am happy.
    It will be a week or 2 for that battery to get here (USA to Canada) due to Customs storage. It is cold here and I can find my way to the garage without the zumo.
    Has anyone else had a problem with their zumo?
    Gar
    Braintree, MA
    Popping the battery out and then re-installing it might fix the problem. It happened to me yesterday.
    Salty Fog Rally 2007, 2009, 2011, 2012, AND LOOKING FORWARD TO 2014!
    -Tom (KA1TOX)
    May 2004
    Petrolia ON
    Didn't Work for Me
    Tom
    Thank you for your suggestion. It didn't work for me. I still have a new battery coming from Garmin.
    Gar
    Aug 2008
    Kingston, NH
    something else to be aware of other than the main battery you can replace.
    there is a smaller internal battery - i had issues with that, needed to send the Zumo to Garmin for correction.
    To minimize that battery from draining i leave it plugged into the wall charger when not in use - since then has been flawless
    Also a extremely excellent forum for all things zumo is www.zumoforums.com
    Check it out.
    2009 G450X White
    IBA #35651
    Rogue Moderator
