Results 1 to 5 of 5
Thread: convert to 12 Volt
    Wave to motorcycle cops Jon's Avatar
    Hudson Valley
    convert to 12 Volt
    I have been riding a 1957 R69 with great success, engine and running gear all rebuilt. No cosmetics. Should I convert to a 12 volt system? What do you think?
    J C Hughes
    "When you play, play hard, when you work don't play at all".
    Colonel Theodore Roosevelt
    Administrator 20774's Avatar
    -1 -- Is that how you disagree? Why mess with success?
    If you don't need the extra juice for lights, vest, etc., or you just run around during the day, I don't think it's worth the change. Plus you might have to be prepared to fix it when out in some remote place. The 6v ignition system is pretty simple. Coils seem to be an issue, though...but there are better replacements these days.
    I do know a guy what what a bent camshaft tip and was having a hell of a time getting it to run smoothly. One option was to install a new camshaft...us shade tree mechanics weren't up to that. He ended up going to the MzB 12v conversion. It solved the timing issue because the ignition is run off the crankshaft not the camshaft. He also got 12v as well. He likes it, though. Pretty pricey...I think it was $500.
    12 Volt Conversion
    If you don't need the extra light a 12 volt conversion gives, I would wait until I had a problem with the generator. Give the durabiliy of these generators, you might be able to wait a long time.
    Rally Rat PAULBACH's Avatar
    Dec 2005
    If it works, why fix it?
    And one it is fixed then it no longer is a true classic.
    Hudson Valley
    Yup, gonna stay with 6 volt. Thanks
    J C Hughes
