Results 1 to 4 of 4
Thread: Foot Peg lowering kit
    Oct 2003
    Novato, CA
    Does anyone have personal experience with a foot peg lowering kit - Suburban Machinery - for example on the F800ST?
    Maybe I'm the wrong demographic for this bike?
    Thanks.
    Registered User dave92029's Avatar
    Jul 2003
    Escondido, CA
    Smile How much do you need it lowered?
    The least expensive way to lower the footpegs is to just remove the rubber insert on the existing footpeg.
    Dave Mishalof
    Escondido, CA
    Charter Life Member # 28793
    IBA # 43
    nevada72
    My bike is a R1100R, but I can vouch for the quality and usefullness of the Suburban peg lowering kit. Very good design, materials and results. I'm sure that it will be just as nice on your bike.
    Oct 2005
    Whitefish Bay, WI, 3mi N Milwaukee
    Exclamation
    I have only good things to say about Suburban Machinery, Inc. Their stuff is tops.
    But if you get the footpeg lowering kit, then make sure you also get the extended shift lever as your angles change. Without the extended lever, the distance from peg to shift lever is shorter by at least one inch (depends on bike and kit).
    "What is beautiful is simple, and what is simple always works"....Kalashnikov, inventor of the AK-47.
    Current bike: 2015 Yamaha TW 200, modified for road/street use with tire, sprocket upgrades. "Center yourself in the vertizontal. Ride a motorcycle...namaste' "
