Results 1 to 15 of 30
Thread: 84 airheads valve recession
Hybrid View
    keelerb
    I was happy, if a bit dubious, to read Matt Parkhouse's article in the latest ON, in which he says that the infamous unleaded gas valve seat recession issues are mostly a pre-1984 issue. I thought the 84s were equally affected? As the owner of an 84 (no issues so far, but I keep a watch on it) I'd love to think this is true but it's not what I've always understood. Thanks - B
    I haven't seen the newest issue yet, but I also thought the problem wasn't fixed until the 1985 models. In truth, the problem was not recession of the valve seat but rather deformation of the valve face itself due to poor heat transfer to the seat. The valve kept getting hotter and hotter and eventually tuliped and fell into the head.
    Oak Okleshen wrote a pretty definitive article in the March 2002 Airmail for the Airheads Beemer Club in which he describes the problems in great detail. He state many times that it is '81 thru '84 models.
    It's easy to mistype something as in '84 instead of '85 or forget to use the word "thru". We'll see how this all shakes out...
    keelerb
    Thanks Kurt. That's my understanding too. I'll continue to monitor the situation and perhaps use a little ValvTect once in a while.... - B
    Friday Yet? 97077's Avatar
    Wis.
    Valve recession
    I had to have a valve job on my 85 R80 RT at 70,000 miles. Why? I'm not sure. My 86 R80 made it all the way to 188,000 miles. My 88 R100RS made it to 126,000 miles. Why the difference between the 3 is a good question. Kevin
    Registered User beemerguru's Avatar
    Foster City, CA
    '81, '84,'88, '92...it really doesn't matter. Any year is subject to valve recession. If you need to constantly reset the valves every 3-5K miles, that's a sign.
    When you do a valve check,,,when you pull the valve covers, is the front of the head a golden brown or dark brown but the rear is still clear aluminum? That's a pretty good sign that somewhere in the past, the head was running very hot. Another reason to pull the head and have a look.
    I always pull the head when I get a bike in for rebuild. I'd say 85% of the time, at least the valve seats and/or guides need replacing.
    Got one with 15K original miles in right now for a complete rebuild..but it sat outside for 7 years. Ya never know.
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    OK - valve problem history primer:
    Starting in 1980 (US model year) BMW introduced new, very hard, no-need-for-lead, valve seats. But the R100 models particularly, and the R80 models too but to a lesser extent, started exhibiting the annoying need for very frequent valve adjustments. When taken apart the exhaust valve heads were found to be deformed, but the seats SEEMED perfect. Early on, shops replaced the damaged valves and left the seats. But often the problem just repeated itself.
    Then BMW determined that even though the valves were deforming it wasn't a problem with the valves really. The new hardened seat material was poor at conducting heat. Valve to seat contact is supposed to conduct heat away from the valve heads. But the poor heat conductivity of the seats caused the exhaust valve heads to overheat and deform. They physically curled at the edges allowing them to pull deeper into the seat - closed up valve gap.
    The real cure was to install the new 2nd generation of hardened seats which did conduct heat sufficiently to cool the valves normally. The second new seat material was introduced in the production of the '85 models.
    This valve head deformation common on the 80 through 84 models is not true "valve recession" in a technical sense. Valve recession is technically the receding of the valve head deeper, and ever deeper into the valve seat as the seat material wears away. And this is typically found on pre-1980 models where the seat material was intended to be lubricated by the tetraethyl lead used in gasoline. The original hard seats were to combat the lack of lead, but the "law of unintended consequences" caught up with BMW due to the heat transfer issue.
    1985 and later models do not exhibit severe problems of either type - but they do exhibit normal valve head and seat wear over time - usually a long time (in miles).
    New Hampshire, USA
    This is also my understanding. And, it can happen to R65/R45 bikes as well, though they are a bit less prone to it as there is a bit less thermal energy produced in the smaller displacement engines. But it still does occur, and the short-stroke motors use smaller diameter valve stems, so the valve head heating can in theory be more critical with detaching the head from the stem on these bikes. I watch my valve lash adjustments closely, and also tend to run the clearances on the generous side of the spec, to give a bit more contact time with the valve seat, cross my fingers, and don't run the air/fuel mixture too lean.
    BMWs in my garage: 1982 R65LS, 1978 R100/7
    sumran
    Thanks for the good information. Mine is a 1980 model, but it has a manufacturing date of April. I am under the impression that my heads are like the '79 rather than the '81, but I may be incorrect. Do you know if the early '80 bikes had the new valve seat material?
