Results 1 to 10 of 10
Thread: GPS screen protective covering failure
    Blue Sky Canadian
    Trail, B.C. Canada
    My new this spring (1st one ever) Garmin has seemed to shed it's skin whilst in New Mexico. Really tough to read when in the daylight and I am afraid that the touch screen option will scratch it. Any comments, suggestions, advice greatfully appreciated. Short term fixes welcomed. Thanks, Glenn.
    Aug 2008
    Kingston, NH
    Don't know the type of GPS you have but there have been reports of screen delamination on some 2610/2720's
    They are usually covered by Garmin - may want to give them a call.
    Another suggestion is to get some of those clear adhesive covers for the view finder on digital cameras, they come in 2" x 2" strips so you could use a couple to cover the screen.
    Braz J Brase's Avatar
    Jan 2005
    Central Indiana
    What Semp said, call Garmin.
    It is a known problem with the 26**/27** Street Pilots. Mine did it when it was almost exactly one year old. Garmin sent me a replacement refurb unit. The new one, now 18 months old, has just developed the first small telltale blister indicating that it too will delaminate soon.
    Someone sells protective film screen covers for GPS units but I don't recall where on the net I saw them. Might google GPS screen cover or some such and see what pops up.
    John
    Registered User heavyjetpfe's Avatar
    Mar 2007
    Snellville, GA
    My 2610 had the protective film on it and it still had the screen delamanate. Unit was almost a year old. Garmin replaced it free no questions asked.
    Danger: Keep Back 500 Ft FredRydr's Avatar
    Jul 2005
    central Pennsylvania, USA
    I tried two types of aftermarket protective films on my Zumo, and threw them away. The OEM screen seems fine without extra protection and works better, because the films adversely affected the touch screen.
    Fred
    Registered User KALTZG's Avatar
    Aug 2004
    Crestview, Florida
    Quote Originally Posted by bluesky View Post
    I had the same problem with my 2610 after three years, so no warranty help. I did find a slick solution. Radio Shack sells a kit of protective film for small screens. There are 4 or 5 small screws that hold the garmin case together. Once the outer case is removed you have total access to the touch screen. It appears that the original protective film is held to the screen with a water soluble material. I soaked a Q-tip with water and gently applied it to the remaining film that was still attached to the touch screen. Once I had the screen clean (all of the old film removed), I cut the new film to size and carefully attached it to the touch screen. Then I reassembled the case and the garmin is like new. I think that the replacement film is a bit thicker than the original film but Ive had no problem using the touch screen. I cannot detect any less sensitivity at all. Ive been using this fix now for 8 months and have had absolutely no problem.
    Gail Kaltz
    1997 GS
    Focused kbasa's Avatar
    Quote Originally Posted by Kaltzg View Post
    I called Garmin when mine was about 3 years old and had delaminated. For $100, they sent me a brand new one, complete with new maps, mounts and other accessories.
    Worth it.
    Dave Swider
    Marin County, CA
    Nov 2007
    Montpelier, VT
    I'll have to run right down to Radio Shack tomorrow and buy one of these kits for my 2610. Do you know the stock number or name of the product?
    warredon
    This may be the one. Catalog #: 16-253 @ Radio Shack Targus TG-RSSP Universal Screen Protectors
    Aug 2004
    Crestview, Florida
    Quote Originally Posted by kpinvt View Post
    The Radio Shack number for the kit that I used is 170.0996.
    Gail Kaltz
    1997 GS
