Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: LED Tail Recommendations
    Frieden mit uns allen drummer's Avatar
    Oct 2006
    Hillsborough, NC
    I did a search on this forum and found very little this topic. I know there have been posts, I just could not find them so forgive me for beating a topic. (Kinda like looking in the refrigerator and not seeing something that is right in front of you)
    Okay, back to topic - I am curious if there are recommendations for extremely bright LED replacement bulbs. I have found a few, but they want you to have a WHITE tail light - nope, not on my bike, red means stop.
    Seems like the white bulb replacements that allow for you to use the red light cover are just as bright as the current filament bulb; which is not bright.
    So rather than spend money on testing various bulbs, I was hoping for a couple of recommendations. Please let me know what LED tail light bulbs you like and if they are extremely bright.
    05 R1200RT
    Duragloss, Sidi, Russell, Olympia, Arai
    Sonor Signature Series (no longer made thanks to AMF buying Sonor)
    These are a few of my favorite things ...
    Registered User soffiler's Avatar
    Nov 2005
    Sterling, CT
    Quote Originally Posted by drummer View Post
    Quick comment on light. Your red lens on your taillight is filtering the "white" light from your incandescent bulb and only allowing red light to pass. If the bulb emitted pure red, the lens would still do exactly the same thing. Allow red light to pass. Red LED bulbs work just fine with a red lens covering them.
    Now, you don't want a white LED bulb for a taillight application. The reason is that "white" LED's really aren't white at all; they emit a mix of mostly yellow and blue. They emit relatively little in the red spectrum. Once you put the red taillight lens over them, what gets out will be rather pitiful.
    Steve O. - MOA #122171
    '05 R12GS, '76 CB200 (wife's)
    '91 K100RS, '87 Honda CBR1000 Hurricane, '84 Yamaha FJ1100, '85 Honda VF500F, '76 Yamaha RD400, '82 Honda XL500... and more
    Mar 2007
    Chicago, Ill
    LED Brake lights
    Hyperlights puts out some fairly trick systems to augment your existing taillights, permitting automatic fast flashing - steady on and other options.
    http://www.hyperlites.com/
    Replacing your existing bulb - at least with my old K, is harder than it would appear, as the system depends on a certain amperage draw from the bulb, if there is less - and LEDs draw almost nothing - the system registers this as a fault.
    Usual disclaimers.
    Hey Chromehead ! bobs98's Avatar
    Nov 2005
    Marlton, South Jersey
    I've had my "Brake" LED setup from Gizmo-Mill for several years, set up to flash before going solid while braking. No problems or issues. I understand they are no longer in business.
    Have also heard mostly positve reviews about Kisan Signal Minder products. Can set up as running lights and flashing brake, I think.
    Run-N-Lights and Light Buddies are now available from the same outfit and advertise in ON, page 149 in the October issue.
    Bob Smith
    1998 R1200C
    2005 Rocket III
    Brake Lights
    As Beemer01 noted, Hyperlights has a nice rig to augment the existing system and they work very well and very easy to install. I've had mine for several years now and you will immediately notice at stoplights that cars will stop one car length or more behind you (I left my flashing - you have the option). I would rate the Hyperlites as one of the best safety features to add to your bike.
    sjc
    Quote Originally Posted by bobs98 View Post
    I believe that the company is back in business under a new name.
    Gizmo Mill is now called Road Rocketeer! Please check out the new website: www.roadrocketeer.com. We are happy to help!
    It's a great product.
    Oct 2006
    Hillsborough, NC
    Soffiler - never thought about the lens being a filter - excellent point, thanks.
    I have been using the HyperLights and they do work well. However, there are times were the sun will wash the tail light out and cars will fly up on my tail. I was just hoping to make my braking more visible.
    05 R1200RT
    Registered User ylexot's Avatar
    May 2008
    Saint Inigoes, MD
    Also take a look at P3 lights. They're brighter than hyperlights....
    www.p3lights.com
    BMWBAGBY
    Brake! by Road Rocketeer aka Gizmo Mill
    Quote Originally Posted by wuli959 View Post
    I agree... it's a great product that was fairly simple to install! My friends installed mine, in a parking lot, in just a few minutes!!!
    Muneio
    Hyper lites here. Very happy with them.
    canadianbrummie
    I replaced my original brakelight with one of these from Nippy Norman in the UK. The LED plate simply plugs into the original bulb socket. 5 min installation. I am also using the original lens, although I am thinking of getting a clear lens. Works very well and is also very bright.
    http://www.nippynormans.com/prodinfo...tem=1&mitem=11
    cheers
    cb
    Registered User MOTOGP's Avatar
    Jun 2006
    Central Florida
    LED Tail lights
    You could always track down a wrecked R1200S and modify the LED lights off one of those bikes for your application.
    I added an LED bar from Custom D[IMG][/IMG]ynamics that was only around $25 that blinks five times before going solid when you apply the brakes. The rest of the time it is like a tail light. Works much better than the stock light, is very lightweight & super easy to install. There are three versions of it. I get lots of comments on how attention getting it is
    mikea
    Hyperlights
    Feb 2006
    Long gone
    Hyper Lites
    Ride Well
