Results 1 to 4 of 4
Thread: r27
    central illinois
    r27
    i am going to look at a r27 this weekend. it looks good in the pictures. they said the carb could probably use a cleaning but it runs ok and stops good. anyone out there have any suggestions on anything to look for special on this model. thanks
    James.A
    The troubles I've had with my R27 over the last 5 years
    Kick starter binding up. Transmission jumping out of any gear when clutching out or applying torque. Tube that feeds oil to the top end on the right side of the cylinder leaking where it emerges from the cylinder base. Voltage regulator delivering charge at the high end of acceptable, cooking 4 batteries in 5 years. 3 of the 5 rubber motor mounts totally destroyed. Carburetor inlet on the bottom of the float bowl with a propensity to leak. Rubber "hardy disc" that buffers the drive line between the transmission and the drive shaft disintegrating. Otherwise a fun ride, except that it is so slow that it is dangerous to ride in modern traffic. That pretty much covers it in my experience.
    Administrator 20774's Avatar
    Quote Originally Posted by woodnsteel View Post
    Other than that, how did you like the play, Mrs. Lincoln?
    James.A
    The rest of the story....
    In spite of these problems, the bike has been a learning opportunity. I have to assume a completely different mind-set when riding or working on this bike as compared to later airheads.
    From a purely subjective point of view, I prefer the looks of a stripped down, un-adorned motorbike. There isn't much on a BMW single that isn't fitted inside the width of the frame. For the same reason, I would prefer a Sportster over an F model if I were inclined to ride a Harley. A larger capacity fuel tank would be a must. Other bikes that conform to this aesthetic consideration would be any Japanese or British single, the Indian 4 and other variants such as the Nimbus and the Sunbeam S-7, even the Yamaha Virago casts a narrow profile when viewed from front on. Conversly, the 6 cylinder Honda CBX is hideous.
    Now then, to stop this hijack in it's infancy, here are some other things for rayma60927 to consider.
    1) The Everbest petcock is a leaker in waiting, My R27 was already fitted with a Karcoma when I got it.
    2) All the rubber parts are by now very old unless they have been replaced. Same with the control cables.
    3) I suspect that most older bikes are under serviced with respect to grease at the steering head and swing arm pivots, including the swingarm on the Earles fork.
