Results 1 to 10 of 10
Thread: It stalls after a fill-up
    On the Road 112124's Avatar
    Apr 2004
    Fullerton, CA
    I've finally determined when it happens I just don't know why. Virtually every time I get gas and fillup my K1200 for the first 10 miles or so afterwards it is prone to stall when I stop. This happens when I'm in town having stopped from 30 mph or on a freeway encountering heavy traffic after going 70mph. The connection is definitely related to having fueled up and will reoccur for about the first 10 miles then it's no problem. After it stalls I can start it without any difficulty. Might this be a fuel injection problem? Any ideas about a remedy?
    Blocking the slow lane
    Edwardsville, IL
    Disconnect your gas tank overflow canister underneath the seat, and try to blow thru the hoses. This is usually the cause of this problem. If its plugged, get a new one.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    Oh yay!!Another DIY fix for an alarming problem we should not experience.
    "Fill the gas tank,it stalls"
    Oh no real prob,just blow into...
    Yee haw!I want me one of them BMWs!They are so reliable!
    Edwardsville, IL
    jgr, you need to blow into the back of the muffler when your bike stalls. Sorta a Canuck version of mouth-to-mouth resuscitation.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Jul 2003
    Left Coast Canada
    I always thought it was suck,not blow when that happens!!!
    Apr 2004
    Fullerton, CA
    Thanks guys. I've come to the point where I really don't give a damn if it stalls because I know I can a)blow b)suck c)be happy I own such a reliable bike.
    P.S. If I'm going to be blowing or sucking should the bike be stopped or at least be going at a relatively slow speed?
    CustomSarge
    can you play nice?
    Filling the tank drops the air volume (headspace) so liquid "hangs". The open-to-air breather isn't right. Get a good answer, disconnections & bypasses void warranties, cheese off the EPA & may just sidestep the symptom for a real problem (although, I'm guilty of Much Worse). Sux to have such a great scoot goofing on said detail...
    Jul 2003
    Left Coast Canada
    Dennis what year is your K?
    If recent enough,this should be a warranty repair.
    I hope.
    Apr 2004
    Fullerton, CA
    it stalls after a fill-up
    jgr451 it's a 2002 LT. After these thoughts expressed I think I will go back to the dealer and have them look at it. The last time I talked with them about it was before I indentified the stalling as happening immediately following a fillup. That should help with their diagnosis.
    AZ
    Definately sounds like a canister problem. Go to www.k1200lt.net and do a search...
