Results 1 to 12 of 12
Thread: salvaging a mildewed leather jacket?
    maine
    I have two older leather jackets . One is a late 80's Hein Gericke Paris Dakar. Both Jackets are mildewed from being stored in the basement. (What was I thinking?) Is there any product available to clean them. Or would sending them out to be professionlly cleaned be the preferred method? Thanks for your imput.
    Mark from Maine
    On the Road EBDMAINE's Avatar
    Jul 2008
    Southern Maine
    Try using saddle soap to remove the dirt first and when they are dry, bury them in cat litter for a few days. That stuff keeps houses from becoming a place not to live in and will do wonders on just about anything.
    How cold was it? shoeman's Avatar
    Jun 2004
    Lake Wabaunsee, Kansas
    Try and find some Skidmore's leather treatment. He makes it and sells it in Wyoming. There is a shop here in kansas that carries it.
    Jim Johnson, OP Kansas
    Marcus Aurelius: "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane."
    #13338 PGlaves's Avatar
    It takes a bit of airing out - or you smell a lot like a pine tree - but I have had the same problem a time or two on gloves and jackets, and I clean it as best I can and give it a good rubbing with Pinesol cleaner. It pretty much does in the mildew.
    Then a good dose of a good leather preservative like Lexol.
    Mar 2007
    If you can find someone with an ozone generator that would do the trick. Hang the jackets in a walk in closet with the generator and run it up for about 20 minutes.Repeat as necessary.
    Nov 2003
    Dartmouth, Massachusetts
    take them to a leather cleaner and have them done properly
    RoyB....
    2007 BMW K1200R Sport (abs),2007 Suzuki dl650 V Strom (abs),2004 Honda VFR (abs),1972 Honda Trail 90,
    2001 Moto Guzzi V-11 Rosso Mandello
    mrich12000
    Quote Originally Posted by RoyB View Post
    Dito
    maine
    Thank you for your suggestions. I am considering having them professionally done. I know I could use a cleaner on the outside but not sure if the liner on the inside would be so easy.
    Thanks again,
    Mark from Maine
    Registered User xp8103's Avatar
    Maine
    +1 here. Years ago, my cat did her business on my old leather jacket. Had it professionally cleaned, don't have the cat anymore.
    Nik #140220 - '88 K75C | '77 R100RS | '06 DL650
    '96 R1100RS - R.I.P.
    '01 525iT (oOO=00=OOo)
    Helmets don't save lives but loud pipes do?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by xp8103 View Post
    But you have a Fur Coat now.........
    Ufda happens..........
    It's all about the details.
    Maine
    more like a "hat"....
    advrider.com
    Oct 2005
    You wanna see some moldy leather?
    You should see the two chairs in the basement of my familys farmhouse.. those things look radioactive.
