Results 1 to 15 of 17
Thread: Stebel Air Horn on K75
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    Have any of you mounted a Stebel Air Horn on a K75 and if so, would you let me know where you mounted it. The stock BMW horns are pretty weak and having one on my F650GS, I see the value of having one on the K75.
    Thanks as always,
    Ken in MN
    On the Road
    Jul 2008
    Stebel Nautilus on K75s
    I mounted this to existing threaded hole on lower triple clamp with 1/8 thick L Bracket that I made. I used the stock wiring and it works fine but I should add the necessary wire and relay I was a bit lazy and pressed for time.
    If you have a "c" model this might not be a good option.
    Jun 2007
    Minneapolis, MN
    Hi Don - thanks for your reply - mine is an "S" and don't think I can mount it there. I'll keep poking around and am sure I'll figure it out.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    It's tight on an S, but they will fit on a bracket bolted to the lower triple clamp.
    The photo Don posted IS an S.
    He was kind enough to remove the fairing for clarity.
    I love the extra volume!!!
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    kayseventyfive
    Below the radiator fairing
    Not a Stebel, I mounted my Wolo below the radiator fairing. Should be similar.
    BTW, anyone have observations, comparisons or preferences for Wolo or Stebel?
    On the Road
    Jul 2008
    Off the bike
    It 's a K75s,Here it is off the bike with bracket behind cylinder,
    About 11/4wide and about 11/2x11/2inchs long and tall.
    Fitment is a little close but it does work and nothing hits,
    that was my main concern. After three or so months everything is fine
    Jun 2007
    Minneapolis, MN
    Thanks to all of you for sharing and really going the extra mile.
    This club is the best kept secret!!!
    Ken in MN
    bmwmick
    Quote Originally Posted by kentuvman View Post
    Thanks as always,
    Ken in MN
    Ken,
    It's pretty easy to separate the two parts of that horn to help you mount it. I did this on my R1100RT and documented the procedure here:
    http://bmwsporttouring.com/ubbthread...021#Post390021
    NateVentura
    Power Requirements
    What did you guys do for power relays? I'm seem to recall the K75 wiring can't provide quite enough oomph?
    I may have to visit Harbor Freight and check out the Wolo...
    bmwmick
    Nate,
    Both the K-Bikes and the Oilheads have 30A relays for the horn. Some have added aux relays triggered by the existing horn relay but I think that is overkill.
    I used to spend lots of time at the Harbor Freight warehouse in Camarillo when I lived in Simi Valley. Neat place.
    Registered User univibe88's Avatar
    Jun 2009
    Newton, MA
    Quote Originally Posted by bmwmick View Post
    Nate,
    So it sounds like on a K75 that you can just pop out the old horn and wire in the new one without a new relay?
    Anybody have suggestions on where to put one of these horns on a K75C? The OEM horn is behind the faring. I doubt there is room in there for one of these big boys.
    Karl
    2007 K1200GT
    1987 K75C - sold
    Aug 2003
    Marion,Ar.
    If possibe keep the stock wimpy horn and add a LOUD life saving horn. Use the stock horn for moderate use such as parking lots to make pedestrians and parking cars aware of you. Use the loud horn for situations where applicable. A lot of people don't realive that big trucks have the usual steering wheel service horn for appropiate situations and the loud air horn for those situations. U don't allways want to blow someone totally away at the crosswalk and parking lot.
    Jun 2007
    Case in point....I came across a guy with an old Goldwing at a big box store. It had a triple horn arrangement mounted on it....Huge, I said it looked like it was from a train....He said Yep, Union Pacific. Then he fired up the bike, started the compressor and demonstrated it. I was literally blown away, but not nearly as much as the unsuspecting guy coming out of the store with a bag of groceries, dropped his bags and actually fell down.....I mean, it was a train horn afterall.
    Jim Douglas '00 K1200RS >136,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    Jun 2009
    Newton, MA
    Wow, I WANT a train horn!
    Karl
    2007 K1200GT
    1987 K75C - sold
    Jun 2007
    Minneapolis, MN
    I have a K75S and installed my Stebel in same position as Picture #2.
    I didn't use the relay because it works okay without it.
    The only thing I don't like about the K75 is hitting the horn is such a non-intuitive movement. I have a hard time hitting it at a critical moment.
    But the horn gets everyone's attention. Very Loud.
