Results 1 to 15 of 15
Thread: Lever covers
    Registered User skidgillen's Avatar
    Sep 2007
    South Dakota
    Lever covers
    Lever covers: What do you use? I am looking to cover my levers with leather or something to isolate the cold from my gloved hands in the cold months of the year. My handgrip warmers work great, but those cold levers while sitting at a traffic light can be unbearable. Any and all suggestions are apprieciated.
    Skidgillen
    Black 2002 R1150R abs
    "I tried being reasonable, I didn't like it." Clint Eastwood
    scqtt
    A year rounder in SD? You must be a tough guy.
    I could never bring myself to put leather on my machine. (OK, well maybe if I could find one of those really cool O.E. leather tail packs they made for the GS back in the day)
    I would try some heat shrikg tubing or some of that vinyl stuff you dip tool handles in.
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Quote Originally Posted by SCQTT View Post
    A year rounder in SD? You must be a tough guy.....
    My thoughts exactly.
    A bit of a different approach, but have you thought of "Hippo Hands"?
    http://www.hippohands.com/Hippo%20Hands.htm
    I use them and they work great.
    John
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    '12 Suzuki DRZ400
    ("kid's" bikes) '02 Kaw ZX6R- Jen's '07 Duc 800ss- Johnnie's
    Go to any harley shop. You will find all kinds of tassled leather lever covers. Go to the dollar store and buy a pair of scissors. Cut off the goofy tassles, leaving a nice (???) leather cover.
    Or put on a wrap of golf club handle or tennis racquet handle tape for insulation and then cover that with big heat shrink tubing.
    However - unless I've forgotten my physics - both the leather or the tape will reach the same cold temperatures as the aluminum just sitting there in the cold wind. So unless you keep your hand on the levers to warm them you will be touching objects of the same temperature whether they are aluminum or leather.
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    ...unless I've forgotten my physics - both the leather or the tape will reach the same cold temperatures as the aluminum ...you will be touching objects of the same temperature whether they are aluminum or leather.
    Paul, never have I dreamt that I would challenge your opinion (I'm serious here - I'm a fan of your seminars & tech articles), but I think you may have forgotten your physics!
    Aluminum is an excellent thermal conducter (witness the aluminum heads on air cooled BMWs). Leather is a relatively poor thermal conducter. Cold aluminum will "steal" the heat from your hands and transfer it to other matter. Leather, being less thermal conductive, will do this at a much slower rate.
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: FY K100RT, '80 XS850 with Vetter Quicksilver, '67 Bonnie, '66 Honda 90
    Quote Originally Posted by alien_hitchhiker View Post
    I don't disagree at all. But he said he had gloves on. So he already had one layer of leather and whatever insulation. I was talking temperature - you are talking heat transfer. I think we are both right.
    My point was just that the leather on the levers would be just a cold as the aluminum inside the leather. With nothing inside the lever to generate heat the insulative qualities of a leather cover wouldn't change their temperature.
    But, if we are talking heat transfer through the leather gloves - then two layers between the hand and the aluminum is probably better than one. Better yet would be a bit of Thinsulite between the hand and glove leather. Because he is still touching those 15 degree levers or lever covers.
    p.s. Remember - I was raised in North Dakota. Tongue on doorknob. Bare hands on flagpole. Fingers on wet hockey skate blades. If there was a way to stick metal to bare skin I probably found it.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Ah Gerbings? Call Gordon's son Jeff. If he doesn't have something to keep those fingers warm I don't know who would.
    Although for South Dakota maybe you will want him to put some extra wire in the gloves.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Sep 2007
    South Dakota
    alien_hitchhiker is right. The aluminum is a thermal conductor and leather is not. The levers suck the heat right out of my Thinsulate lined gloves that were nice and toasty warm from my grip heaters. I think I'll try the shrink tubing first. I haven't found any other lever covers that I like so far. Thanks for the input everyone.
    Skidgillen
    Polarbear Polarbear's Avatar
    Clovis,CA
    Find neutral more:)
    When I stop at light, I'm almost always in neutral, so holding a lever is no issue. AND, if in N.Dakota in winter, you may want to find a way to "heat" the lever. Seems simple to me, but I am no electrician! Wire the lever, as it is aluminum and should carry a current well and get warmer. OR, run some current in a wrap around the lever, with say a fine wire and then cover the wire with your leather, heat shrink,etcetc... Invent these and you may sell many...Randy
    Registered User nytrashman's Avatar
    Nov 2007
    westchester co. NY
    get some hippos hands, best cold weather gear you can buy
    Registered User bmwgsrider's Avatar
    Amarillo, TX
    Quote Originally Posted by nytrashman View Post
    +1
    Hippo hands made all the difference in the world.
    scqtt
    Quote Originally Posted by bmwgsrider View Post
    +1
    Do hippos have hands? How did they come up with that name?
    I am going to make a new version of license plate bolts.
    I think Chicken Lips would be a good name for them.
    SCQTT
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    SCQTT
    That would be a great name for those beak-protectors I've seen on GSes.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    I gotta remember to buy (or make my own) Hippo Hands.
    I'm a rounder.. on an airhead. No heated grips, no heated seat, not heated jacket. Just a heated engine.
    scqtt
    Quote Originally Posted by The_Veg View Post
    A beak protector? Another great idea, I think I'll call them Fish Toes.
