Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 54 of 54
Thread: Tire Plugger gets a D-
  1. #46
    Just me rad's Avatar
    Santa Cruz
    My experiences mirror most of the folks here. I have used the rope plugs, BMW plugs and the Stop-n-Go plugs. Only one of those three has failed me. Yup, that would be the Stop-n-Go. Failed me two times and also failed on a friend‘«÷s tire when we were riding together.
    The BMW ones work, but they are a real pain to insert; I don't carry them anymore. I carry the rope and glue ones and a Dynaplug kit I got last year. I have not had the chance to try the Dynaplug yet. As a matter of fact, I hope I never do
  2. #47
    GREGFUESS
    Talking
    I carry both the Stop-n-Go and the wax ropes. The fairies of flat tires has taken note, and I have never had a flat. Now that I have jinxed this record...
  3. #48
    From MARS
    I've used the Dyna Plugs. They work great! I found them easier to get into a smaller hole than the ropes are.
    Tom
  4. #49
    Sep 2006
    Carry a kit with different plugs for different punctures, even some tire & tube patches for serious out in the boonies repairs or for my tubed friends.
    The only time I had Stop-N-Go plugs fail was in my RT's OEM Dunlop the first time I used one and did not ream the steel cord enough to keep it from cutting the plug at the head and spitting it out. Have seen some Metz Z6's with wire coming out of the reamed hole but after some serious rasping the plugs stayed.
    It depends on how far I need to ride on a tire as to what I use and how long until I can permanently repair or replace the tire back at the house. Helen's 1150 got a test with a DynaPlug on a tiny leak Monday as I will replace that tire next week anyways. I have run string and plugs over the course of a long trip...a few times maybe the life of the tire. All about Risk Management.
    Steve Henson
  5. #50
    Registered User froggy's Avatar
    Feb 2010
    Ballwin.MO
    BMW tire plug
    When I purchased my RT last year I noticed a factory plug kit in it so I did not purchase a rope kit for it.I have used these ropes all my life.Well this past winter I pulled everything off the bike for its winter check-up and decided to open the sealed clear plastic bag with the seal kit in it.What the heck are these D shaped plugs,and how do they work.Do they work well or should I go out and buy some of the rope sealer that I know works?
    We drove all this way for a DEAD END ! My son!!!
    02 Silver RT1150 My 1st BMW Bike ...Totaled 2/23/16
    13 Black R1200RT 90th Annv
    Craig
  6. #51
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by froggy View Post
    The oval BMW plugs are the reason for the comment above about them being hard to insert (at least without tearing). An odd choice for a plug shape, but they do work -- IF you can get one inserted without ripping it apart with the insertion tool!
    On the rest of this thread: I've always carried a Stop-n-Go kit, and it worked on both occassions I needed it -- but now you all have me worrying!
    To Dynaplug or not to Dynaplug, that is the question ... [insert rest of the Bard's work here].
    Mark Neblett
    Fairfax, VA
    #32806
  7. #52
    Apr 2006
    Nibley, UT USA
    Gummy worms to plug the hold long enough to get to where you can do a real repair.
    For a real repair you need a core and patch, inserted from the INSIDE of the tire.
    Yes, you have to dismount the tire to patch it, but you end up with a permanent repair that allows you to get the rest of the service life from your tire without overly compromising safety. Core-and-patch repairs are the only repair method tire manufacturers recommend, to the best of my knowledge. An example of one brand of core-and-patch is here:
    http://www.wheel-weight.com/Tire-Plug-Patch-165.html
    I usually just pick these up at local ATV places, they all seem to have them on hand.
    Best,
    GTRider
    DGerber
    1983 R80ST -- 1988 K100RS (r.i.p.) -- 1995 R1100RSL (gone, never forgotten) -- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
  8. #53
    Clovis, NM
    I have used the Stop-N-Go kit once on my 11RS, several times on Rob Lentini's RS when we rode 3Flags, and several times on other riders bikes to help them out.
    I read the OP's post and firmly believe he did not use the kit they way it was intended. It takes me longer to get the kit out and ready to use, than it does to ream the hole good, put the nozzle tip on the reamer and push it into the tire, and insert the plug. Yes, on completely deflated tires.
    In the case of the one on my bike, I punctured the tire just north of Amarillo, TX. I plugged it, inflated it to 40 lbs and rode to my home in Clovis, NM. The following day, I checked the pressure - no loss of air, and rode it to Deming, NM to Deming Cycle Center where I had it replaced - 400 miles from Clovis.
    The multiple plugs used in Rob's rear tire were the result of multiple punctures. He had to replace that tire in Regina, Saskatchewan. Though it was well into the cords with multiple plugs in it - the tire was still aired up the morning after we arrived so he could ride it down to the Harley dealership there [awesome dealer BTW] where he got the tire replaced to get home.
    I carry worms as a backup but have never needed them. Used as directed, the Stop-N-Go kit has always worked for me.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
  9. #54
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    I've used the Stop-n-Go tire plugger on my Volvo and my 1200RT with no problems.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
