Results 1 to 10 of 10
Thread: Low Beam Bulb Change in 10 Minutes!
    Sheboygan, WI
    Thumbs up Low Beam Bulb Change in 10 Minutes!
    I know this topic may have received a fair amount of attention before, but not sure if what I 'discovered' today was included.
    After first struggling to try and change out the right-side low beam bulb on my R1200RT, I felt that after about two hours of frustration trying to get my big paws inside those cramped quarters, that was effort enough, and called it a day. Able to get the old bulb out, but setting the new one in place and securing it...yeah, right.
    Had scratches, marks, minor bleeding and still no fixed headlamp.
    The 'engineer' who designed a headlight assembly that cannot be removed from the front for servicing should be taken out back behind HQ in Munich and have his knee caps broken!
    I was going to leave it to my local dealer when next week, the bike goes in for valve adjustment (30,000 miles) and an oil change.
    But it annoyed me that I failed at so basic a task as replacing a headlight bulb, which someday, I may need to do on the road.
    I wondered how they might magically do this at the dealership, given that my mechanic has similar sized hands.
    Wandering the local Advance Auto Parts store for inspiration later in the afternoon, I came upon an AmPro 24" Flexible Mechanical Finger.
    $6.00
    It neatly grasped the H-7 bulb by the upper connector prong and allowed me to slip it into the socket, rotate as needed and hold it there (at the proper position) until I could snap one of the retainer clamps into place.
    Then I released the flexible tool, nudged the other clamp-arm into place, reconnected the wiring and closed up the access port.
    10 minutes....job done. No new trauma to my hand / wrist / arm / ego.
    That little gem will easily fit into my trunk or sidecase and comes with me on roadtrips from now on!
    Sounds very useful! But I couldn't find it on the AutoZone website.
    Paul L
    '04 BMW R1150RT
    '82 Yamaha XJ650RJ
    Haluzak recumbent bicycle (hey -- it has 2 wheels and is great exercise!)
    Sheboygan, WI
    Unhappy
    Quote Originally Posted by Ride2wheels View Post
    That's because as I drove past it tonight, I noticed it is Advance Auto Parts.(NOT Auto Zone, which is further down the block - Oops!)
    By the way, saw the same tool (Craftsman) at Sears in their tool department this afternoon - $1 more ($7).
    Sorry about that - just so exited to find a way to tackle that almost- impossible- to- get- at right-side low beam!!
    Jul 2008
    Laramie WY
    BTW, I discovered after some frustrartion that the right side bulb is a lot easier to put in place if the bike is on the center stand rather than the side stand.
    '12 K1600 GT
    Feb 2005
    N. Dallas 'burb
    I had similar issues. There's just not that much room for an adult male's hand. And there's certainly too little room for your hand and being able to look at what you're doing. My solution has been a pair of long nosed pliers.
    Grant
    '05 R1200GS
    Former owner of an '03 R1150R
    BMWMOA #113847
    Sheboygan, WI
    Smile
    Quote Originally Posted by mistercindy View Post
    Tried the needle-nose approach, but unfortunately, that means one of my hands was in the way of the other.
    With this tool, my left hand rests on the tank, while the other sneaks in for the clip.
    Hey...if what you do works, go with it!
    Registered User soffiler's Avatar
    Nov 2005
    Sterling, CT
    Quote Originally Posted by Greenwald View Post
    ...The 'engineer' who designed a headlight assembly that cannot be removed from the front for servicing should be taken out back behind HQ in Munich and have his knee caps broken!
    It occurs to me that the vast majority of modern vehicles including cars, light trucks, and motorcycles are equipped with headlights that cannot be removed from the front.
    You've got a LOT of kneecaps to break, globally.
    Steve O. - MOA #122171
    '05 R12GS, '76 CB200 (wife's)
    '91 K100RS, '87 Honda CBR1000 Hurricane, '84 Yamaha FJ1100, '85 Honda VF500F, '76 Yamaha RD400, '82 Honda XL500... and more
    Polarbear Polarbear's Avatar
    Clovis,CA
    GS/GSA are real easy;
    My friend paid a dealer 40+$$$labor to do his GS headlight bulb. WHY? I know some of the bikes are hard to get this job done, without injury. My last KLT was a body wrenching experience, too, way up under the fairing. The new GS line are quite easy, so anybody with these, do your own and save. The two headlamp cups are right out in the open, in front of the ignition key. New tools like you've found for the RT are always cool to find. I do the same, always looking for new tools. My weakness's are hardware stores and tool stores. Randy
    Sheboygan, WI
    Talking
    Quote Originally Posted by soffiler View Post
    When I retired from the force, I kept my expandable metal baton, my second-growth hickory one, and bought a new AR-15.
    I'm ready to go 'engineer-hunting!'
    Sheboygan, WI
    Thumbs up
    Quote Originally Posted by Polarbear View Post
    Exactly!
    Learned long ago that finding the right tool for the job is what it's all about.
