Results 1 to 13 of 13
Thread: Starcom1, CB, Intercom Advice
Hybrid View
    kdoddrell
    Dear All,
    I am wondering if someone could give me advice on a number of fronts in regards to a Starcom1 Digital, Zumo, CB Setup:
    Rider to Passenger communicatons:
    My girlfriend has an open face helmet and has the mike with the boom on it. Ever since day 1, she has only getting sound out of one ear. Is this a common problem? Do we need to replace the speaker and mike kit in her helmet.
    Secondly, I can hear her perfectly. When I speak it sort of distorts back into my own ears and she complains it is distorted. I have mic vox 1 set up (low). What would be causing this?
    Third, I have installed the Midland CB and hooked it to the Starcom1. I can hear really well from the other rider, but he says that my sound is very muffled and he has difficulty hearing me. When unhooking the CB from the Starcom1, it works fine. Any thoughts. My BMW dealer said it was because the cable between the CB and the Starcom1 was not shielded.
    Many thanks for your advice anyone
    Kevin
    PS. Installed on a R1200RT.
    Unregistered user norton's Avatar
    Aug 2005
    Plano, TX
    Swap out the passenger and riders headsets in the different plugs to see if it exhibits the same behavior in the other helmet plug out. The helmet speakers are very sensitive to placement. Try gently twisting the helmet while it's on her head side to side to see if there is any sound out of the suspect speaker. Better yet remove the speakers and mic from the helmet and plug them in as a naked set up and see if the speakers really work. There could be a bad connection or broken wire on the headset.
    Try turning sidetones off if they are on. Adjust the microphone sensitivity to about 70% on and turn down the volume.
    Is the radio bike powered, or are you using it on bike battery power? If you are using a power cord from the bike then you should have a shielded power cable. Until you rule that out you can't go any farther. CB's on BMW are more difficult to set up so some patience with trial and error are called for. Grounding is what most folks struggle with.
    kdoddrell
    Hi Norton,
    Thanks for the reply.
    I will try the speaker removal when I get the bike back from the dealer, to see if I can fix the back speakers.
    On my mic, I have it set to low Vox. When you say switch to 70% sensitivity, is that the mic vox or is there another setting on the Starcom1. I had always suspected that the speakers were distorting because of overload. When I am stopped and there is no bacground noise, I can speak quietly with no distortion coming back into my speakers. As soon as we are moving at any sort of speed the distortion starts.
    I am powering the CB off the bike battery with the power cable running under the tank. I will run the CB on it's own battery and discinnect the power cable to the bike battery. You reckon that could be a good test?
    Cheers
    Kevin
    Danger: Keep Back 500 Ft FredRydr's Avatar
    Jul 2005
    central Pennsylvania, USA
    Quote Originally Posted by norton View Post
    [COLOR="Red"]If you are using a power cord from the bike then you should have a shielded power cable. Until you rule that out you can't go any farther. CB's on BMW are more difficult to set up so some patience with trial and error are called for. Grounding is what most folks struggle with.
    Please explain this further. I have a Starcom1 Advance (not digital), Zumo 550, mobile phone and a Yaesu VX-6R. The Yaesu is powered from its rechargeable battery most of the time (I recharge it at night), but sometimes I plug it directly to the bike's 12 volts. The power cord is a lightweight zip cord that came with the unit, to the end of which I soldered an SAE connector. Should I be using something else for the power cord?
    Fred
    kdoddrell
    I spoke to the Starcom guys and he was most helpful. When I get the bike back this weekend, I am going to run the CB off the CB battery and then I am going to shield the power lead from the bike battery to the CB.
    I am also going to isolate the helmets and try and fix the intercom as well.
    Let you know
    Kevin
    Jul 2005
    If you have excellent support from a Starcom dealer in the USA, please share who it is. Thanks.
    Fred
    Aug 2005
    Plano, TX
    Fred, How is your radio working? If it's OK then your set up is OK, If you are having issues then shielding and ground are the first area to look at. AM radios (non FRS type) are less common in the BMW world, but very popular for Goldwings and HDs.
    There is a mic sensitivity portion to the Starcom1. If the mic sensitivity is turned down and the volume is turned up they are fighting each other. With the ability of the unit to increase the volume when the noise/speed increases it maxes out the volume and could cause some distortion if it's too high.
    Running the radio off the battery eliminates some of the power variables and is a good test. It rules in or out the power source as the cause of distortion.
    I have had excellent support from http://www.spoiledbiker.com/. No affiliation, just a very satisfied customer.
