Results 1 to 15 of 16
Thread: gps dash mount
Hybrid View
    On the Road kmEatr's Avatar
    Hamilton, Ontario, Canada
    gps dash mount
    anybody ever made a dash board for mounting gps, radar, ect. that uses the 4 fairing bolts (2 side, 2 front) that are above the gauges and below the fairing as mounting points ?????
    dlearl476
    You mean like this:
    RCU Designs.
    Make sure you're sitting down when you ask the price!
    Slowpoke & Proud of It! BRADFORDBENN's Avatar
    State of Confusion
    Not sure of your model, but check out this...
    I have an RCU accesory shelf on my RT and like it a lot. Take a look at http://www.bmwofsaltlake.com/rcu/ If you want to see it installed, check out http://www.bradfordbenn.com/beemer/a...?acc=1&model=1
    Took me about five minutes to install.
    -=Brad
    It isn't what you ride, it is if you ride
    thanks for the info. does a gps-v fit under the windshield with the antena up ? might try making my own.....
    On the Road DaveinOKC's Avatar
    Jun 2004
    Oklahoma City, OK
    I use a GPS V on the RCU shelf. The Garmin oval-shaped mount is affixed as far back as it will go (closest to the rider) and centered. In that position, you can point the antenna in a horizontal position. The windshield needs to be just a few degrees up from the full back position.
    Good luck with it.
    State of Confusion
    I use the external antenna for better resolution, so I do not have the problem. You can also get a low profile antenna.
    -=Brad
    in the end for a quick solution i made my own mount. went to the local street sign repair guys and asked for a scrap piece of aluminum. got out my hack saw, my drill, and a file. make a template out of a piece of cardboard, traced it on the metal, cut it, drilled it, put black vinyl tape over it, used 1/2 inch strapping to cradle it........and viola.......a mount in about 2 hours and a cost of under $5.00 canadian and fits under the windscreen
    after the rally i'll take it off and make a nicer one, one that looks more like it was bought, a little cleaner lines.
    State of Confusion
    Thumbs up
    Very Cool!
    -=Brad
    Jun 2004
    Oklahoma City, OK
    Nice job. Looks just like my RCU mounting & about 50 bucks cheaper. I gotta start using my head first, wallet second.
    Ride safe.
    Focused kbasa's Avatar
    Marin By God County, California
    Love that odometer reading KMETR. Yeah, I know it's Km, but still....
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    State of Confusion
    Yea, 85,481 miles is a nice big number.
    these are real numbers and calculations... no IBMWR fun
    -=Brad
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    Now you're talken !!! [IMG]BMR Products[/IMG]BMR products
    WOW.....now that's a shelf. might take me a little longer to make something that good.
    Hey, that BMR mount, can the stuff be on the shelf when the windscreen is down ????? All the photo's show the screen in the up position. Unless it is raining I usually ride with the screen down.....95% of the time.
    Feb 2004
    Dallas, Texas
    KMETR,
    The windshield goes all the way down for sure. The only catch is if you are using a stubby GPS antenna, the antenna has to be in the horizontal position and not vertical. Don't have a GPS yet so I can't say if that's a drawback. BMR doesn't seem to think so.
    Randy
