Results 1 to 8 of 8
Thread: R100/7 Preventive Maintanence
    MOTOBOBP
    What parts may fail?
    I'm getting ready to take a 5000 mile tour with the wife on our 1977 R100/7. She won't appreciate being standed in North Dakota.
    I'm wondering about the Dyna III ignition, alternator, coils, rectifier, etc. The bike has 60,000 miles on it. All the obvious maintenance has been done, splines lubed, valves adjusted, drive train gone over, steering head checked and lubed, etc. Dyna III has been on the bike for about 30,000 miles. Everything else is original. Bike is currently running fine.
    Thoughts?
    Thanks a lot guys!
    Blocking the slow lane
    Edwardsville, IL
    Take the easy stuff.....clutch cable, tubes and equipment to change them, full toolkit, etc. I wouldn't worry about the electronic ignition at all.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    James.A
    prevention
    I always carry a spare clutch cable everywhere I go. The only other thing that I would suggest would be a diode board.
    rocketman
    I carry a full set of cables (including front brake) on my R100/7 as well as the original points plate, points and capacitor, I've never had a failure of the Dyna III on mine, (40k and counting) but being a black box affair it's non-repairable, so I keep the old stuff with me just in case.
    Change out all gear and drive oil if you haven't done so in the last year, look for exssesive iron fillings etc.
    I travel everywhere on my '78 with total confidence (70k and going).
    RM
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    If you're "getting ready" to go on a tour, and it's a month or more away, just change the carbs and clutch cables now. It's cheap insurance. If you ride it for a month, and there are no obvious problems, you'll be ready for years to come.
    My Dyna III has never failed. Replaced once...but only because of a faulty diagnosis...it was a coil that had been a fault. That's about 130K miles of no-problamo usage.
    Get a tube repair kit. Learn how to use it if you don't already. Carry a spare tube, cel phone, Anonymous Book, and a credit card. Have fun.
    Mac
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    CAPT_CURMUDGEON
    Best thing to bring along on an extended trip is the right attitude and riding gear. If you are reasonably warm, dry and calm you can solve a whole heck of a lot of problems than if you are cold, wet and in despair. I have limped home on one cylinder but have always made it on my '82 R100. My advice is a nice set of tire irons and a spare rear tube. For some reason nails and screws left behind by thoughtful craftmen tend to go for the rear tire.
    Have a great time.
    Capt Curmudgeon
    (currently sitting in a motel in Grand Forks, ND).
    rocketman
    Have a great time.
    Capt Curmudgeon
    From what I've read that's because when the front tire rolls over a nail it can catch the head in such a manner that it "stands it up" just in time for the pointed part to puncture the rear tire. I've also read that a mud flap on the front tire can help prevent this from happening, but can't say if that true or just an old riders tale.
    RM
    DrCurve
    R100/7 spares (more)
    Spare float bowl gasket, piano wire probe for trash in main jet, tail light blub, blinker light blub, several 10mm nuts for valve covers, J B weld, original points and point plate kit, small test light, one spare plug, one spare plug wire, ect. Best,
