Results 1 to 8 of 8
Thread: Stalling K1100
    NWKRider
    Unhappy Stalling K1100
    '95 k1100lt stalls at low idle SOMETIMES. Only restarts with full thottle. Has anyone else experienced this problem. Had injectors serviced.
    Brookfied WI
    Have you checked your battery?
    I had this problem with my K100RT. It felt like it was running out of gas when it was indeed the battery.
    I don't think the battery was even getting enough juice to run the computer.
    I replaced the battery which was 5 years old and have not had the problem since - that was 2 months ago.
    NWKRider
    gsmetal Thanks for replay Newer Battery Bike dies instantly Before I found that it would start with full thottle you could crank it forever with out starting
    bmwmick
    K,
    Has your fuel mileage gone down drastically too? It sounds like it is running VERY rich. The coolant temp sensor and the air temp sensor could be defective causing the Moronic to think the engine is always cold and calling for more fuel.
    Frank Warner has a good write-up on the sensors here: http://www.geocities.com/fwarner_au/...injection.html
    Mick
    NWKRider
    mick no loss of fuel mileage. only other symptom is somrtimes it won't run under 1500 or so rpm till i hit the open road. Thanks for
    Warner link. good info. K
    asajecki
    Started having that problem recently. Have you checked for bad gas. Drained the tank, refilled and added Techron. Seems to have worked.
    What's that noise...? basketcase's Avatar
    Alabama
    Very likely the fuel filter. For some reason, when they need replacement they normally act out all of a sudden.
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    Stanardsville, VA
    Does the bike do this while the engine is cold or all the time when idling? I'm not a mechanic by any means, but last summer after having the bike serviced my bike would cut off only at the first stop sign about a mile from my house. Turned out they had tuned the bike so the idle speed was too low, causing the problem.
    Just a guess.
    02 R1100SBX Prep
    93 K1100LT
    75 R75/6
