Results 1 to 12 of 12
Thread: Driving Lights for R12RT
    On the Road
    Aug 2007
    St. Petersburg, Fl
    I am planning to add driving lights to my R12RT. Motolight with the new caliper mounting came recommended. Are these lights as strong as the high intensity PIAA? I'd prefer PIAA but is there a R12RT mounting kit available for them??
    Aug 2005
    NE Ohio
    Not sure about the strength as compared to the PIAA's but there is a kit available to the RT. The caliper bolts are replaced as well so do not substitute any bolt for these.
    Focused kbasa's Avatar
    Marin By God County, California
    If I recall correctly, Motolights use a 35W halogen bulb.
    I'm not sure which PIAAs you're comparing them to, but if you're looking for night time illumination, I'd bet the PIAAs are a lot brighter. I've got a pair of 520s on my GS and it's like daytime when they're on.
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    On the Road
    Apr 2005
    Mountains of Southern Oregon
    Hella FF50s
    Make motolights look like glow sticks. I've had them on both my RTs and wouldn't leave home without them.
    Feb 2007
    Southern Delaware
    PIAA 1100X located under the oil cooler on my 06 R1200RT. Cycle Gadgets mounts. I had to aim they down a lot as I was being flashed by on coming traffic often even in the day time.
    AZ
    Quote Originally Posted by KBasa View Post
    Yes, but you can get higher wattage replacement bulbs (MR-16) from Motolight or here:
    http://www.bulbamerica.com/MR-16-Bulbs-192-cat.htm
    The Motolight caliper mount is much more rugged than PIAA 1100's and do not interfere with the suspension travel.
    MOA #107139
    RA #28511
    YB #2005
    Sheboygan, WI
    Thumbs up
    Quote Originally Posted by 4NBike View Post
    Have the identical set-up on my '05 R1200RT. I even had my tech wire it up so that they are activated by my OEM HIGH BEAM switch - no additional buttons installed or exposed wiring.
    A buddy I ride with has MotoLites on his bike - also bright - just liked the install of the PIAA's better.
    Good Luck With Either!
    PS: However, my garage looks NOTHING like this guy. Seriously good-looking shop, Man!
    Feb 2007
    Southern Delaware
    Thanks,
    Yep anal about my garage, I wired mine up to a separate switch so I can run them on or off when desired
    Registered User DPWiegs's Avatar
    Nov 2006
    Omaha, NE
    I had a follow up question regarding the PIAA 1100s on an RT. The Cycle gadget EZ mount is not recommended for non-ESA RTs and I noticed that PIAA sells an RT specific kit (74124) also...my question is does the PIAA kit have the same limitations regarding install on non-ESA bikes?
    I'd really like to install the PIAAs below the oil cooler as pictured above but I'm leery of impeding any shock travel and causing pieces to bump. FYI I no longer have the OEM shocks installed but switched to Ohlins about a year ago.
    Dave
    Current: 07 Silver R1200RT
    03 Silver F650 CS (sold)
    Thanks,
    Got any more pictures of the paint on that?
    Dave Swider
    Marin County, CA
    Jul 2007
    THE BIG SKY
    Question
    Thanks,
    I've got a PIAA kit in route. Cannot tell from you pictures, are the lights mounted to the bottom of the oil cooler shroud or to the side on the fairing panels? Existing holes or did you drill new holes?
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Feb 2007
    Southern Delaware
    KBasa, I am guessing you are asking for pics of the paint job on the motorcycle, attached.
    AK: The Cycle Gadgets mounts, mount to both the oil cooler shroud and the inside of the fariring lip, yes you have to drill holes, not a problem EZ job just follow the instructions.
