Results 1 to 15 of 18
Thread: Autocom Vox & Wind
Hybrid View
    Asheville, NC
    Autocom Vox & Wind
    I've searched and can't find a similar post- but I'm sure this is a common issue and I'm hoping someone has found a solution. I just installed an autocom and I thought it worked great until I took my first ride with a passenger. Unfortunately my passenger needs/likes to ride with her visor open much of the time. With her visor open the vox constantly gets set off, muting the music and putting amplified wind noise through the ear speakers. I have an R12RT w/an Aeroflow w/s so I'm pretty sure I've created the best case scenario for wind management. Even with vox set at least sensitive setting the issue occurs. She's wearing an Arai full-faced helmet and I've checked to make sure the microphone is adjusted appropriately with the tan side towards her mouth. If it's not possible to make this work with her face shield open I'm wondering if it's possible to rig her microphone so that it's push-to-talk instead of vox...that way she can blast her face with as much wind as she wants and I won't have to hear it! Any ideas/suggestions?
    Jay
    '08 R12RT
    Denver, CO
    Jan 2008
    El Paso, TX
    Have you installed the foam windsock over the microphone?
    Asheville, NC
    Quote Originally Posted by ljjohns View Post
    Mine didn't come with an additional windsock- it's covered in an oval-shaped foam that's black on one side and tan on the other. The manual says tan side toward mouth, black toward the helmet chinbar. I'm going to head to radio shack per jcridge and see if I can purchase some additional foam and reposition her mic in the hopes that it will cut down on false triggers.
    Jay
    '08 R12RT
    Denver, CO
    Jun 2006
    Berkshires - Massachusetts
    Quote Originally Posted by 109398 View Post
    Same problem here. Go to the dollar store and buy a stereo headset and use the foam pieces from that. 50 cents apiece!
    glennhendricks
    Stupid question
    OK, maybe a stupid question but here goes.
    I wear earplugs because of the wind/helmet noise. So how do you hear a communication system when you're wearing earplugs?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by glennhendricks View Post
    Huh?
    Ufda happens..........
    Aug 2005
    NE Ohio
    Here's how many do it including myself.
    Etymotic Research ER6i Isolator In-Ear Earphones
    Autocom In-Ear Speaker Headset Extension Lead: Coiled
    jcridge
    My Autocom system has plenty of volume to overcome road noise and ear plugs for BTB, MP3 and cell phone. The MP3 and cell would sound much better with earphones but for the most part the system works great with foam ear plugs at 70MPH. If you set up the Autocom for use with earplugs, you will never again forget to put your ear plugs in....it's loud.
    Registered User lionlady's Avatar
    Forest, VA
    The Autocom system has two base volume settings: "with earplugs" and "without earplugs." I wear earplugs when I ride... Dog forbid I should forget to put the earplugs in, and hook up the Autocom... even an indrawn breath of surprise can be painfully loud.
    That is the only "problem" I've had with my Autocom system.
    P
    Courage in women is often mistaken for insanity.
    R1150R Rockster, Limited Edition!
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    Believe it or not, you actually hear communication and music better with ear plugs than without. Earplugs cut down on the wind noise so the voice or music comes through pretty clear.
    The older systems were set up that way, but their new systems have independent volume control for both rider and passenger.
    Asheville, NC
    Called Autocom- they have a kit like you described and I was reassured that it would fix the issue as it is, apparently, a common complaint they get when customers install the system. I'll install when it arrives and update here. Thanks again for the suggestion.
    Jay
    '08 R12RT
    Denver, CO
    +1 on that question
    I had to add them. A bit pricey for what you get. Should come included with the kit. Mine wore out pretty quickly so I went to the Dollar Store and fitted a $1 headphone foam to it (you even get an extra!)
    Feb 2004
    Dallas, Texas
    It's very important on the Autocom system that the mike is kept up against the lips. Not an eighth or quarter inch away, but against the lips. So much so, that sometimes the mike needs to be pushed into the open mouth to put tention the boom to keep it firm against the lips.
    It's designed this way with a sharp fall off to avoid wind noise. There's nothing unusual about riding with the visor of a full face helmet cracked or wide open. If the mike is away from the lips, it will pick up wind noise. The voice is gone after a quarter of an inch.
    Their foam wind sock might help, but it is intended for flip up helmets or 3/4 helmets.
    Depending on which Autocom you got, they make a second discrete mike which points out the back of the helmet to sense wind noise and adjust volume levels.
    The push to talk button is only going to help on bike to bike communication when you want to keep your on bike conversations private.
    Quote Originally Posted by RTRandy View Post
    I
    It makes a significant difference on full coverage helmets also. Not might, it does.
    jcridge
    Jay,
    I have an Autocom with a full face HJC and ride with the visor up allot of the time. The mic needs to be mounted as low as possible and near as possible to the center of the lips. I have my mic tilted slightly downward. This seems to help somewhat, but if she's getting the buffeted wind off the windscreen it's going to set the VOX off. I have my VOX setting about half way and it works perfect with the shield closed and cuts out at times with it open at speeds up to 70mph after that I need to have the visor closed. Extra mic foam ( Radio Shack)on the mic will help attentuate the sound the mic hears, this should help.
